Heisler two barrel carb and manifold info |
Post Reply ![]() |
orangeone ![]() Bronze Level ![]() ![]() Joined: 11 Feb 2015 Location: Iowa Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Feb 2015 at 7:38pm |
I have a Heisler two barrel manifold for my AC and am in search of a carb for it any info will be a help thank you Andrew
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11994 |
That's interesting. Never heard of a Heisler manifold before. What AC engine does that fit? And, what brand carburetor goes on that? Just curious...
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21905 |
I have one that was designed for a WC or WD. I no longer have the carb, which was two-barrels/two throttle butterflies, so it makes the manifold kind of useless. It was not for a WD45, as the carb hose was the smaller diameter. I think their goal was the increase the HP of a WD to try and match the WD45
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3912 |
i never seen one like that mush be a proto or an r&d part ??
No. It was a go-fast part just like M&W pistons/sleeves.......Sherman overdrives, etc, etc. I'd sell my manifold for $50 if someone wants it.
that sure has me interested
TexasAllis ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: Texas Points: 396 |
Pictures?
1944 Allis C
1960 Allis D-17 LP |
Steve Zidlicky ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Bolivar, MO Points: 325 |
Heisler made both manifolds and heads for 2 cylinder john deere's. they were for more power. the manifolds while still all one piece had the intake runners designed to run cooler thus more power from cooler fuel and the heads were "flat heads" for more compression.
I would be interested in your manifold where are you located? please text or call me at 641 -352-0327 my name is Andrew and I am in central iowa and my e-mail is allischalmers53wd@yahoo.com
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
heisler made lots of aftermarket parts-transmisson parts and kits-step up an down
Post Reply ![]() |
