7010
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Topic: 7010
    Posted: 05 Feb 2015 at 2:40pm
how much operating pressure does a 7010 have? the tractor spec page doesn't show for 7000 thru 7080! I have the flow but not the pressure
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2015 at 4:55pm
2500 psi max to the remotes and 3 point.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2015 at 5:54pm
if you have flow and no pressure - where are you measuring? If at remotes, check the stand by - set to 450 or there abouts then pull the remote and adjust the high pressure on the compensator..... IF you turn it in or add a shim or two and it doesn't come up quickly - stop and post back - you may have rare but bigger issues...
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2015 at 8:41pm
I had to add shims to one of my 7020's to bring it to 2500.   readily available at agco dealer and wasn't tuff to do!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2015 at 8:41pm
i'm trying to buy a machine and the manuf. says it has to have 2500-3000 operating pressure to work! thanks! there isn't anything wrong with the 7010!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2015 at 9:45pm
No problem with pump to pump 3000 psi, but lines and hoses could become a problem.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 4:00am
lines and hoses on the tractor or the machine? or both?
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 6:09am
Both shameless ,I would try to get it set as close to 2500 as possible, saves future headaches .
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 7:12am
Not another snow machine........? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 2:07pm
Darrell...nope!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 2:08pm
thanks Mack and Puller...i'll mention this to the factory!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 5:02pm
The pump only has pressure when there is resistance to build pressure. The pump only puts out low pressure until it is needed. To check pressure you will need to restrict the flow.
