d-15 govenor help
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Topic: d-15 govenor help
    Posted: 03 Feb 2015 at 6:57pm
governor all sloppy on series 2 gas d-15
I ordered all my stuff and am wondering how to get the bronze bushing out of the front governor cover. I figure I can drive it back in with block of wood along with the busing on tach end of things I can drive it out. but not this one
thanks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2015 at 10:04pm
Many years ago I saw an old tech tap the bushing with thread tap - screw in a long bolt, then submerge the cap /cover into hot oil - and pull the bushing out.   Don't know what model tractor it was but principle the same....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2015 at 10:14pm
Thread the bushing like tbran mentioned. You can use slide hammer, or piece of all thread with a section of pipe or large socket.If you use the pipe or socket,slide it over the all thread, put a washer over end of all thread, start a nut on all thread and tighten it till it pulls the bushing from cover. HTH Tracy
This page was generated in 0.430 seconds.
