WD-45 front axle?
LSilseth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LSilseth Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 front axle?
    Posted: 02 Feb 2015 at 7:31am
What type of grease or oil do you put in the front cast housing (wide front) on a WD-45?
When we pulled ours apart it was really runny.
Thanks
  Luke
MN FARM BOY
Luke
www.silsethfamilyfarm.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2015 at 9:09am
Originally they had gear lube. Most of them won't seal well after so many years and a light corn head grease works fine. Grease the bearing like you do a wheel bearing and pump some in with a zerk. Good to go for years again.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2015 at 9:55am
I thought I was doing the right think putting gear oil in mine. After about a week, it had all leaked out (and made a wicked mess). I pumped in some synthetic grease from a grease gun (like Charlie said above) and it has worked well.
