Allis chalmers B pto hydraulic swap
jimbob0406 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbob0406 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers B pto hydraulic swap
    Posted: 21 Jan 2015 at 6:36am
I have a 1950 allis chalmers B. When i bought it it did not have a pto or hydraulics. It had the differential cover with the pointy cone. So i went on ebay and bought a pto hydraulic assembly. but now it looks like i need a gear that goes on the end of existing shaft and retainer clip. Is this so? anyone do a swap maybe a couple of pictures anything be highly appreciated.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 8:20am
Yes you need the drive gear. They are on ebay frequently,
 http://www.ebay.com/itm/VINTAGE-ALLIS-CHALMERS-C-TRACTOR-PTO-DRIVE-GEAR-SNAP-RING-1948-/300927289498?pt=BI_Heavy_Equipment_Parts&hash=item4610aa089a
Or put a WTB in the classified section of this site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbob0406 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 8:48am
Thank you i appreciate that. Since i have a later year B would that be the same as the C drive gear you posted by chance or should i look for one from that year?
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 3:03pm
The gear was all the same.  We mounted them all the time and there was not a problem putting a newer 1 3/8" PTO on an older unit 1 1/8" PTO without changing out the gear that was on the unit.
Take good care of my favorite.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbob0406 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 7:18pm
So the C had a touch bigger shaft than the B is what your saying?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 7:48pm
   no yrs. was the difference-1  1/8 early later  an 1   3/8
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 8:30pm
1 3/8 spline is standard size, early tractors had 1 1/8 and you would have to add an adapter to fit a regular PTO shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbob0406 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 7:40am
Well if I have any questions i know where to ask. Also do people RTV the housing or is it recommended to get a gasket? If so does anyone have a part number or one on Ebay? 1 more thing What year color was on the 1950 B. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 8:13am
You need the gasket. The AGCO number is 70225385 current price is $7.45
(original Allis # was 225385, Agco numbers start with 70)
