Hydraulic Oil transferred to Transmission Reserv
rrbarton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrbarton Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Oil transferred to Transmission Reserv
    Posted: 08 Jan 2015 at 6:56pm
I own an Allis Chalmers 200. I fill hydraulic reservoir to full. Tractor runs fine for a time. Then the hydraulic oil gets transferred to the transmission reservoir. I have to stop and pump it manually back and then the issue starts again. Any idea what is causing this to happen?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 7:19pm
Welcome to the forum. It's most likely the seal on the input shaft of the transmission. That requires a split at the rear to fix, and I would replace the PTO seals while there.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 8:31pm
Yup, seal blown.  Search the forum - this is discussed in detail
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrbarton Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2015 at 11:51am
I tried searchinG for previous forums on this. Any suggestions on what to type in for the search?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2015 at 12:03pm
To search on here, use a google search and add allischalmers.com to the end of your entry.
 If you want to get by, I have seen guys remove both drain plugs and add a tee to each compartment so they could connect the 2 together. Kinda farmerized, but it works on some of the older tractors for a temp fix.
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2015 at 3:29pm
I've had the same problem with my D17.  Goes a couple months before I pump it back. $4.00 hand pump vs. splitting the tractor.  Not all that bad but I will get it fixed when time/money come together.
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2015 at 9:32pm
When you T the two togather you will have one too full or the other too low. If you fill it to trans. level, you over fill PD causing PD clutch to run in oil which churns the oil, heat the oil, and takes HP. If you run trans. low as PD, you could seaze first gear(or others) to pinion causing big $$$$$$$$$$ damage.    MACK
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2015 at 8:43pm
had a 190 xtd doing the oil switcheroo too and tractor got a new owner!!! thanks; ac fleet
This page was generated in 0.083 seconds.
