Toeing Front Wheels on G
John Kenny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Kenny Quote  Post ReplyReply Direct Link To This Post Topic: Toeing Front Wheels on G
    Posted: 05 Feb 2012 at 7:34pm
Thanks to everyone who is assisting me with this restoration.  I appreciate the help.
I  am bringing in the front wheels on my G now, first brought over the spindle supports to set the tires at a 48" spacing, matching the back.  Now of course the wheels are pigeon toed and I thought this would simply be a matter of loosening the lock bolt that is located on the spindle arm and jacking the front end up and twisting the spindle.
It will not budge.  I am not sure which spot to attack.  I have tried knocking in the tie-rod into the socket which is stubborn and not budging and also tried twisting the spindle with a pipe wrench.  Is there some trick to this that I don't see?  The only mechanical inhibition to this thing moving seemed to be the lock-bolt, but spindle will still not turn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 7:37pm
Takes patience. It it the tie rod that needs attention. Don't clamp on tube. You need a solid way to hold it. Might use heat, depends on the severity of rust. Patience, patience and lots of love and Kroil. Good Luck, Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 8:22pm
-Tie rods look somehting like this. YOu remove the clamp on the center tube, soak the threads with penetrant oil, then screw it in or out to "toe" the tires.-
