timing marks on a 190xt fuel pump? |
troy(el paso, il) ![]() Silver Level ![]() Joined: 28 Sep 2009 Points: 124 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jul 2012 at 5:25pm |
Hello All-
Have a question about the best way to go about turning over the engine on a 190xt in order to line up the timing marks on a Roosa fuel pump. Just tried getting a wrench on the crank nut, but it's pretty tight quarters. Any advice is greatly appreciated. Thanks in advance.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8356 |
Usually from the pump side or underneath , it maybe quarter turns but alot of times that mark is hard to see; or underneath the flywheel/clutch theres a hole for a big screwdriver etc to catch the flywheel teeth , then have someone watch
Edited by DougG - 30 Jul 2012 at 7:14pm |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2559 |
Troy I turned mine over from the alternator side carefully with the fan and putting tension on the belt. If you go past your mark I found I could not back it up, had to go around again. I turned the engine oner more revolutions than I care to remember! You can use the starter for some of it, but when the 25^ gets anywhere close you have to go really slow, and 4 eyes work better than 2!
bill2260 ![]() Silver Level ![]() Joined: 30 Mar 2010 Points: 217 |
Used the starter first to get it close in the window on the pump. Then I removed the starter and used a pry bar to move till they line up. Bill
