Three Point Hitch Conversion D17 III
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Topic: Three Point Hitch Conversion D17 III
    Posted: 27 Sep 2019 at 5:42pm
The Cross 3 point hitch conversion won't work on my D17 Series 3 Serial Number 67086 because the Allis hitch bracket is too wide for the Cross anti-sway bracket that is supposed to straddle and bolt onto it.  Cross Mfg says that their kit should fit all WDs and D17 Series 1,2 and 3 but according to the parts book it looks like Allis widened this bracket at SN 24001 & up.  The Allis bracket is about the same overall width as the Cross anti-sway bracket so there is no way that I'm confused as to how to install it - it won't fit.  I'll stand corrected if someone can post a picture.  But until then, before I start cutting and welding, has anyone else run into this and have a recommended fix?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 7:20pm
Sounds like a series 4 hitch.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 7:56am
I have a hitch from a series 4 on my series 2, but I don't have the sway bar braces on mine to say how well they fit.  The sway bar brace that OK Tractor sells looks to be built with 2 sets of pin holes for the wide vs narrow drawbar hangar.
AaronSEIA
