Switching from power adjust rims to double bevel
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Topic: Switching from power adjust rims to double bevel
    Posted: 29 Jun 2020 at 8:17pm
This is probably a dumb question, on my 7050 the power adjust rims are rotten. I found a like new set of rims that take the double bevel clamps. I've got wheel weights on, so I cant get a good measurement on the wheel casting. To change rim types will I need to change wheel castings also? Thanks Fella's
Edited by DIESEL - 29 Jun 2020 at 8:18pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 8:32pm
I think the wheel centers are the same. You just need the clamps. Check the part numbers of the centers in the AGCOpartsbook.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 9:13pm
I'll try that Joe, I was sure they were the same size but I got the tire shop involved and they are telling me otherwise. Eyeballing across a wheel weight just hasn't been very accurate.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2020 at 2:04am
Think Joe is correct, you need 16 of the clamps. At least that's what it takes on 200 or 7000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2020 at 6:59am
And if you want to be on 30 inch row spacing, you cannot get that narrow without power shift wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2020 at 7:06am
Thanks for the help guys, I just ranch so row spacing isn't an issue.
