Steering Gear Leak on Allis G
Skuter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skuter Quote  Post ReplyReply Direct Link To This Post Topic: Steering Gear Leak on Allis G
    Posted: 10 May 2012 at 2:13am
Noticed a leak on my steering gear.  Any one know the best way to fill and adjust the "steering gear," (one that is painted over).  I checked the aftermarket I & T but the information is lacking.
Am I effed?
Any help appreciated.
Thanks
Skuter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 8:49pm
Skuter, it is a Ross steering gear. Pretty simple to adjust. Bearing are adjusted by removing shims. The cross levershaft is adjusted with a set screw in housing cover plate. You must adjust it while  turning wheel to extremes right and left. It will get tight at the extremes, because of less wear. If your pin is worn out, I can fix that. HTH Tracy
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 9:51pm
Skuter, check your private messages
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 10:09pm
If needed I can e-mail you a scan of that gear box, it breaks down the parts very well.
Dusty
