Starters again. 7020
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Topic: Starters again. 7020
    Posted: 05 Apr 2017 at 6:49pm
Posted below about replacing a Lucas starter on a 7020 with a Denso gear reduction starter. I found an genuine Denso starter that is listed as fitting a 6070, 6080 and 8010(on Denso's own website) for 381 from an actual Denso dealer, and 441 from another dealer that I trust(who says it's a genuine Denso) so I think that's the direction I'm going to go.        Are the starters on the 6070, 6080, 7020 and 8010 factually identical? Will it bolt up to the tractor no problem? (other than maybe needing cable modifications)
Edited by joe - 05 Apr 2017 at 6:50pm
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 7:36pm
The 433 is the 4 cyl version of the 649.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 7:52pm
I kinda figured that based on displacement. Thank you for confirming. So the bolt pattern is the same then?
Edited by joe - 05 Apr 2017 at 7:54pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 8:18pm
Yes.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 9:13pm
We have used them for years with great luck. On some they like a socket head screw for one bolt.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 2:54am
On the 190 xtd the length of one bolt had to be 'maanaged' because the hole was blind It was the top one on the outside - easy to see and easy to fix by adding washers under the head of the bolt. Really makes start nice
