Starter on a b
lowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Topic: Starter on a b
    Posted: 15 Aug 2018 at 3:18pm
Can a guy put a starter on a b That did not come with one do you have to get a driffent flywheel or can you put one on the flywheel that is on it thanks
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:56pm
You would need the flywheel, clutch, and torque tube with the starter hole.  Plus the battery box and cut down tool box.  If your block isn't drilled for the generator, you'd need a battery charger a couple times a year.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 7:09pm
Ok thanks
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 8:47pm
What year is it my war time C had the flywheel with ring gear and starter hole in the torque tube. Just no starter generator or PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 9:28pm
I thought he said it was a 1939 will have to check next time I'm over there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 10:10pm
39 dosent have a starter hole in the torque tube. No gen mount bosses on block no ring gear on fly wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 10:12pm
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 11:52am
So what would it cost for a tube and flywheel
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 2:06pm
In the long run it might be more cost effective (and easier) to purchase another late model B with a starter. Then sell your hand crank only B to recover some, if not all of your expenses.
Either way, good luck with your project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 2:36pm
The motor is out so be just to see how much the parts are little more work
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 6:35pm
I have the parts you are looking for. Located in Elk River MN lselkriver@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 6:59pm
Thanks I will keep you in mind trying to find some one closer to me found couple yards by me thanks
