starter cover on hand crank |
Hubnut ![]() Orange Level ![]() ![]() Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Apr 2015 at 6:57am |
What covers the hole for the starter on a hand cranker? I want to keep my C solely a hand cranker.
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
I believe that the early hand crankers didn't have a hole at all....
Different torque tube.
my 2 cents.
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
I concur.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
I have seen pictures of the C that were hand crank tractors from the factory, after they discontinued making the torque tube without the hole, that had a cover like a core plug. You could most likely make one out of 16 gage steel. Make a cardboard pattern, cut the steel slightly larger, lay the cut piece on a bag of sand and tap from the center out until you have a slight dome with it sliding in the hole. Probly have to file to fit. You would not need a very high dome, just enough to cause it to expand tight in the hole when you flatten it when in the hole against a stop at the outside. You would need to make a stop inside the hole to install it with the torque tube on the tractor. With the torque tube off you could use a starter drive end slid in from the inside as a stop. It looked much like the one used in the first power take off units. ![]() Edited by Dick L - 07 Apr 2015 at 7:59am |
Bill Deppe/AC Salvag ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Seems it was commented the knock out plug on the back of a WC differential was the same
GreenOrange ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wisconsin Points: 849 |
Bill is correct - the differential cover from a wc was the same used to cover the starter hole.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Bill is spot on I just looked it up and the rear plug from a WC with ser# 67328 & up out of a cast iron rear end will fit, they have the same part number. AGCO #
70201814
There ya go!
Thanks all.
sandman2234 ![]() Orange Level ![]() Joined: 21 Feb 2013 Location: Jax Points: 2547 |
I have one that I purchased from Matt(Mn) if you want a pattern.
David from jax |
A proud member of the Allis Express movement!
Northeast Florida |
Matt (Jordan,MN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Jordan, MN Points: 3802 |
I have nos and used plugs for sale. Send me a pm if your still looking. Thanks Matt
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
