Snow removal |
Post Reply |
BrianC
Orange Level Joined: 16 Jun 2011 Location: New York Points: 1613 |
Posted: 20 Nov 2011 at 4:20pm |
On a small compact tractor such as a John Deere 2570,
which would be better for clearing driveway snow, a front mounted blade, or a rear 3pt scrape blade (swinging offset, reversible). Thanks |
oldironguy
Silver Level Joined: 01 Oct 2010 Location: Shoreview, Minn Points: 367 |
From my Minnesota perspective, I'd say definitely go with the front blade. Reversing the blade is a pain, especially when it's really cold. Or go south.
Dick
mtanut
Orange Level Joined: 13 Sep 2009 Location: sandy lake, pa Points: 545 |
The front mount will do a better job, but most end up with a rear mount because of the cost difference. Factory front mounts will be power angle and power down.
I have a 185 Allis, 6060 Allis, Model K gleaner, SMTA ferg 35, ferg 20 (paps first tractor, Allis B (wife's)John Deere 240 skid loader and a bunch of the usual farm stuff.
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
I'm also a MN. snow remover person-- so my preferance would be anything on the front, ideally a loader. many years ago I worked at a
Gulf gas station and owner had a furgeson with a back blade and it was a pain useing backing up all the time but I must say did a good job.
Rick of HopeIN
Orange Level Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1296 |
in southern Ohio all we ever had was tractor with rear blade and loader. But we did not get snow that often. We moved a lot more manure than snow and rear blade was on the loader tractor most of the time anyway.
Al in WMA
Silver Level Joined: 12 Sep 2009 Location: Massachusetts Points: 158 |
I take the loader off the 25 hp 4WD Yanmar and put my 6 1/2 foot power angle plow on to handle my 900 foot long driveway. Last year we had a little over 100 inches of snow! When the banks need to be pushed back I put the rear blade on and roll them over. Rarely use the loader in the winter.
Education is what you get when you don't get what you wanted.
RMD
Silver Level Joined: 07 Oct 2009 Location: Connecticut Points: 300 |
A front mounted blade that you can angle to cast to the side is always the most efficient. The main anvantage with a rear blade is on unpaved driveways - you can push with the back side of the blade and it wont dig into the ground.
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
This should be your choice! Not AC but Orange!!!
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41203 |
I used a rear mounted blade and loader bucket for about 3 years to do my own 400 ft drive as well as a large church lot. Reversed blade and pushed snow going backwards. Bucket was 7' with the extensions on it and would go fwd and stack snow , then clean up going backwards.
Next was rear facing snow blower (2 stage) which worked better than the backblade.
Next was Jeep Commander with a 6 1/2' Myers plow, then 3/4 ton Chev with Western Pro 71/2' blade. Something about being inside a cab, dry, warm, and not looking backwards just makes things better.
Going forward anytime is easier than trying to look over your shoulder .
that Case blower looks like a single stage. Keep thinking of getting a blower for my New Holland small tractor for cleaning up around house and shop where it's hard to get the pickup close or between.
Now have a 8 1/2' Boss plow on the 2000 GMC and will make the 11th year with that truck.
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
BrianC
Thanks all. Sounds like the front mounted blade is a favorite.
What I have been using is an AC 160 with 6ft grader box pushing backwards. Going forwards with the box means the wheels will lift off the ground and spin, unless I take little bites. I don't have a rear scraper blade. But they are cheap and universal. I need (like to have) a small narrow tractor like that JD 2720 to fit in tight area (blueberries in this case). So I thought I would would get a decent snow removal solution in the deal. Finding a used one with front plow blade may be tough. New is an option, haven't bought a new toy in a long time (since April). Humm, new tractor toy vs inexpensive 3pt attachment to old tractor. |
1946WP
Orange Level Joined: 25 Apr 2010 Location: mn Points: 780 |
I FOUND IS TO JUST LET THE WIFE SHOVEL IT.
Post Reply | |
