snap coupler lift latches |
old school allis
Joined: 10 May 2020 Location: central MN Points: 69 |
Topic: snap coupler lift latchesPosted: 10 May 2020 at 6:37pm |
does anyone have any advice for removing the rivets to replace the springs because in my experience if they break off your out of luck
1957 d14,1963 d17 series 3,1963 d15 series 2,ca,c, 2 b 10's,and a big ten
MACK
Posted: 10 May 2020 at 9:23pm |
Grind a flat place on edge of head and work spring over it. MACK
NE GA Allis
Posted: 10 May 2020 at 9:46pm |
MACK I think he is talking about the rivet itself, not the spring on the rivet. |
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s, 1 WD45, 3 D15D’s, 1 D17 |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10933 |
Posted: 10 May 2020 at 9:50pm |
They are hardened drive screws. They are a pain to get out. Heating them with a torch will soften them. A vertical mill is best to get them out. HTH Tracy
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3980 |
Posted: 10 May 2020 at 9:56pm |
I just did two sets. I clamped a good set of vice grips on the rivet heads and just started rocking them back and forth until I could feel a little movement. Then took a hammer and knocked them out by hammering on the vice grips from the back side and they popped right out. Installed the new springs and drove the pins back in with a dab of red Locktite on each one.
D14JIM14
Bronze Level Access
Joined: 25 Jan 2020 Location: Brazil, indiana Points: 190 |
Thanks(1)
Posted: 11 May 2020 at 9:35am |
I had D17 that the latch rivets were very rusted and bent . I wanted to replace them and couldn't work them out . So I heated the with a torch and melted candle wax on them and they came out with a little twist very easily !
old school allis
Posted: 11 May 2020 at 10:23am |
thank you for the great suggestion
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 11 May 2020 at 4:55pm |
I've seen a lot of them that were snapped off at auctions, so you can't get ahold of them. I don't have a mill, so now what?
old school allis
Posted: 11 May 2020 at 5:11pm |
the last set that i did i heated them up until they were red hot and let them slowly cool down and they were soft and i started to drill them out and then i used a bolt extractor (bad idea) but it snapped off. so no i have a snap coupler lift latch with a bolt extractor stuck in it. so now i am just going to try welding the rivet head back on and filing a it down so i can get the spring over it
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 11 May 2020 at 5:30pm |
Ideally, I'd heat them cherry red, then as they go to cool, stick a bees wax candle against them, let the wax wick its way in. Then set a pair of vice grips on them, real tight, and wiggle back and forth. most of the time, this works for me...
Bill Deppe/AC Salvag
Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 976 |
Posted: 11 May 2020 at 10:44pm |
What size drill bit?
Tracy Martin TN
Posted: 11 May 2020 at 10:53pm |
Pretty sure the carbide cutter I use is .218 diameter, or 7/32. If broke flush, you can carefully weld a nut on them, let it cool and twist it out. HTH Tracy
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25242 |
Posted: 12 May 2020 at 5:52am |
Anyone ever see an 'after market' clone of them ???
old school allis
Posted: 12 May 2020 at 6:45am |
djs tractor parts is where i usually get mine
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1590 |
Posted: 12 May 2020 at 8:19am |
I did mine a couple years ago on WD45. Grind a bit off the rivet head - very carefully. Force the washer off. Once the washer is off get new exact size washer. Install spring and repeen. Was lots of material left to repeen. Did excellent job and I replaced all 4 springs. I’ll maybe see if I can post a picture later. Take your time. Have it in a vice to make it easier.
