|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Snap Coupler Latch rivet removal |
| Post Reply   |
| Reindeer   Orange Level     Joined: 14 Sep 2009 Location: Calgary, AB Points: 650 |  Post Options  Thanks(0)  Quote  Reply  Topic: Snap Coupler Latch rivet removal Posted: 03 Jun 2018 at 12:35pm |
   So I started out this morning with plans to replace the rivets, and springs on the snap coupler latches.  First thing I managed to do was break off a rivet while removing a spring.  I thought maybe I could drill out the stub, but they are harder than the surrounding cast, so will be  difficult to drill without making a mess of it.  Other option would be to try to press them out the back, but casting is very irregular, and hard to support properly in the press. I'm sure others have been in this pickle.  Any suggestions? | |
| DougS   Orange Level     Joined: 03 Nov 2011 Location: Iowa Points: 2490 |  Post Options  Thanks(0)  Quote  Reply  Posted: 03 Jun 2018 at 1:24pm |
   Can you grind the head off and drive the rivit out with a punch?
| JW in MO   Orange Level     Joined: 16 Feb 2010 Location: South KC Area Points: 2670 |  Post Options  Thanks(0)  Quote  Reply  Posted: 03 Jun 2018 at 3:23pm |
If the other side is open, clean it with a slightly smaller drill bit, then use a pin punch to drive the rivet out.
| Reindeer   Orange Level     Joined: 14 Sep 2009 Location: Calgary, AB Points: 650 |  Post Options  Thanks(0)  Quote  Reply  Posted: 03 Jun 2018 at 6:07pm |
   So far I have tried drilling, and pounding.  The last thing I did was to heat it up with a torch, and then pour water over it .  Well rusted in place. Head is gone.  I left it to cool off and will get back to it in the morning.  Seemed to lose its temper with the heat, as I could get a good divot in it with the  center punch after several cycles of hot and cold, but not earlier.   Will attack with the drill in morning.  Hoping that does the trick.  The other side has a rivet in it as well so the fight continues   | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
