Slinging the Drawbar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Slinging the Drawbar
    Posted: 07 Sep 2012 at 7:45pm
I was going to post pics of this to the thread a while back about all of us old geezers having trouble 'slinging' the drawbar into place on our tractors.  Didn't take me long to figure this one out and it sure has saved my back and arms, not to mention FINGERS!
It has a shelf where you can put the wrenches, pins etal. too.  I don't have a patent on it, so feel free to copy it.  LOL
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 7:50pm
Hey thats cheatinWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 7:58pm
How does it work on a dirt floor:) I used to have a home made bracket on my 45 drawbar for the No. 5 JD sickle mower. It added about 50 pounds to it. I took that of aboout 19 years ago and haven't used the mower since. Just made the DB toooooo heavy.
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 8:10pm
Not to hi-jack this post,,,,,but I got a question for you guys. About every single wd you see the bail that holds the drawbar up has been broken and welded. how does that happen? We have had a couple  since near new and have nevre broken that piece, but every one I buy has had it welded.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 8:33pm
   I always tell my buddy's young boys as they watch me throw it  on, "You will be a man when you can do this, but, they just stare and never ask to try, sigh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 8:37pm
I always figured they lost the pin outta one side to break the bail but don't know for sure.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 8:48pm
i used to have a problem getting the snap coulper draw bar put on when i was younger. i just sat on the ground under the tractor and put the cross piece of the draw bar on my legs and use my legs to lift it up there.
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 9:02pm
Those aren't nothing compared to a D-19 draw bar. That will really test your manhood or end it. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 9:48pm
I was going to add that the D15 drawbar is heavy also. I can mount the D14 and CA, but the D15 is a chore.
Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 6:34am
I'm a 'cheater' too. Got 3 D-14s and have ALL the drawbars collecting dust as I never use them. I made a 'SC carryall' frame that has a 2" sleeve on it.Primary use is an 'offroad' forklift(spmehow acquired 3 sets of used forks..),but the sleeve allows me to pull anything like the tandem discs,trailers,etc.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 7:02am
So would it work to just balance it on a floor jack and roll it under the tractor then jack it to the correct hieght?
The universal answer to all questions is yes, how much do you want to spend?
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 7:29am
I think Ted has the right idea...I got a bunch of wood going to waste, so may waste a few nails to put something together.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 7:48am
Necessity is the mother of invention  - why do it the hard way if there is an easier way that gets the job done --- I still use the sitting on the ground method -- D17D.
John (MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:22am
Boy I just read some good news! I use to not have a problem throwen the WD drawbars, but can't manage the D19 and was thinking it was an age issue. Glad to hear they are heavier and it ain't got nothin to do with age.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:41am
Charlie, it works pretty good on dirt floors too.  That is a piece of outdoor carpet it is on.  Easier than laying on the ground getting dirt into every part of your body.  I have mostly sand and it works good.  Couldn't do it sitting anymore, got cramps almost every time I did it.  This suits me just fine!  Hardest part is lining up the holes for the pins.
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 9:27am
Thanks for the idea Ted.  I have one of those Harbor Freight furniture dollys that I filled in the open center with a piece of 3/4" plywood to move heavy stuff around the shop.  It will be perfect to make a box to sit my CA drawbar on when I need to mount/dismount it.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 9:45am
I've noticed the one on my D17 seems to have got heavier lately, so I sling it on a chain from the lift arms and lift them up to where I need it and sling it into the bell, then adjust the lift arms to line up the pins.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 10:06am
Ted, I like that idea, with my friend Arthur Itus starting to take his toll, I will be able to get those bad boy's off and on alot easier, should have Mike Noonan draw one up and start selling them. Also with it bolted to the floor and set at the right height you could just back right in!!!!
