serial numbers wd 45 |
theACkidWD45 ![]() Bronze Level ![]() ![]() Joined: 28 Mar 2012 Location: Latrobe PA Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Mar 2012 at 6:39pm |
i recently purchased a supposed 1957 wd 45. i researched the serial no. locations. the one on the left brake housing is not there i took the paint down to bare metal and still no luck. any help in locating the serial no would be greatly appreciated i want to verify the yr
John (C-IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
Look at the engine number and cross reference to Bryan Smiths chart. The other possibility is on the top flange of the hydraulic pump. I have several with serial numbers there, but they don't always match the tractor number.
Edited by John (C-IL) - 28 Mar 2012 at 6:49pm |
RickUP ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 803 |
It's NOT ON TOP of the left brake housing. If you stand behind the tractor, it will be facing you. (I have a feeling you knew this). Scraping the paint should have revealed it. Had to do this to mine. Look some more I guess.
im not around the tractor now but i did find a serial number infront of the shifter
i had the entire tractor down to bare metal and i couldnt find any numbers on the left brake housing kinda stumped
That number in front of the shifter is cast into the housing. Sorry I never looked into what it's for,but the serial number will be stamped.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Early WD's were stamped on TOP to the right side of the left brake cover. All 45's should have a stamp on the back of the differential housing unless it has been replaced.
![]() If it is a curved shifter and there is no stamp were indicated, take a look at the hydraulic pump housing and compare engine numbers here:http://people.clemson.edu/~wsmth/SNFind/esn_tsn6.htm |
it does have the curved shifter and no inspection plate on motor. just no stamped or casted no. in the indicated location
Some wimp on the hammer stamped mine. It's very hard to see with my old wimpey eyes. Ya gotta look close. It's real fact.
the man i bought the tractor from gave me the original owners manual and still no luck but ill look on the pump housing. thanks for the insight.
