SC blade cutting edge
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Topic: SC blade cutting edge
    Posted: 12 May 2018 at 9:29pm
Is anyone making the bolt on cutting edges for the SC blade?  I am in need of one.  I will also need the edges for the extensions too.  Thanks in advance.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 9:34pm
If I am not mistaken I read before that Cat makes one that fits? Hopefully someone else will chime in. Ryan
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 10:35pm
Standard road grader cutting edges bolt right up to the main blade.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 11:56pm
one for western snow blade works an looks good also' an price is right on them also.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 5:30am
I bought one from Cat a few years ago. I forget the number now but at the time it was only around $60. The top lip on it was maybe 1/4" too tall as it didn't quite roll in tight to the blade. If you search the forums for my screen name and snap coupler blade, you should be able to find the discussion and pictures I posted.
AaronSEIA
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 11:05am
Yes there has been discussions on this topic in the past.  Seems that Cat makes a cutting edge that will work and someone mentioned there is a lighter cutting edge they make that works and is less expensive.  A few years ago, I bought the cutting edge from Cat and had to cut it down off each end to 18" for the extensions.  3 out of 4 holes matched up and could be used.  Still have a chunk of the edge from the center left.  Don't know what I'll ever do with it, but it's a nice piece of iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 11:51am
Found an old receipt for the cutting edge I used for the extensions.  Part #8D-2786.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 11:59am
Here is a prior discussion on the cutting edge.  Part #7T-1633H was the lower priced cutting edge.  http://www.allischalmers.com/forum/rear-mounted-blade-replacement-cutting-edge_topic115463_post934958.html?KW=cutting+edge#934958
