SAE 20 wt oil.
Kruger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kruger Quote  Post ReplyReply Direct Link To This Post Topic: SAE 20 wt oil.
    Posted: 21 May 2021 at 12:30pm
Checking the fluids in my D 17.  Hydraulic is slightly low, service manual recommends SAE 20 oil, non detergent.  I can't find it locally.  Is there a viable substitute?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 12:31pm
MODERN DAY UNIVERSAL TRANS/HYDRAULIC FLUID...….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kruger Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 12:53pm
Thank you, can that be added to the present oil or should the old oil be drained and replaced. Appreciate your advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 1:55pm
If it was mine, it would get changed....every compartment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 4:43pm
Change it now and dont worry about it for another 10 years. UTF can be purchased at any Farm Store, Napa, Wal Mart, etc..
as Dr said... transmission, hydraulics, bevel gear... can all use the same.
Edited by steve(ill) - 21 May 2021 at 4:44pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 5:46pm
He may have trouble locating the 'Bevel Gear' in his D-17.
Perhaps you could give him some further advice.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 7:36pm
Power steering ahead of the radiator. Takes about 5 quarts. Fill just above the steering gear. Overfilling will vomit out the excess. Drain plug on the right rear corner underneath. Takes 1 1/8" wrench.  Hydraulics takes about 2 1/2 gallons. Drain plug on the bottom of the sump pointing straight down. Same wrench. Power Director also takes about 2 1/2 gallons. Drain plug straight down from the clutch pedal. Same wrench. Transmission/differential takes approx 6 gallons. Drain plug directly under the seat. Swing the drawbar to the side. Same wrench.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kruger Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 9:09pm
Thanks. Answers a lot of questions
This page was generated in 0.067 seconds.
