Rental Truck to Haul B |
cfciii03 ![]() Bronze Level ![]() Joined: 20 May 2021 Location: 43560 Points: 29 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Jan 2022 at 11:24am |
Can anyone advise as to a commercially available truck (flatbed or other) that I can use to transport a Model B ?
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24705 |
Up here in Ontario , you cannot rent a pickup from any 'car rental place'. They don't want the liability .....
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12005 |
I would say find someone locally that has a rollback and have them pick the B up and bring it to your house. OR maybe you know someone with a car trailer that you can borrow that person, their truck n' trailer and pick it up that way and pay them for their time and fuel. Steve@B&B
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87952 |
the B weight is about 2000 pounds so any 1/2 ton truck is capable of pulling a small trailer to carry the B. As Steve said, a 2 axle car trailer or utility trailer is preferable to a 1 axle trailer.... but can be done if your not going a long distance or higher speed.
nella(Pa) ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3124 |
I haul mine in the bed of a 3/4 ton pickup.
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Non running or running ,makes alot of difference in loading if no way to pull or push on .
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
Its all a matter of Balance...
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54167 |
If it aint rinnin, its a lot easier to push or pull it up the small ramp onto a landscape or car trailer...
Dave76 ![]() Bronze Level Access ![]() Joined: 26 Mar 2015 Location: Hebron Illinois Points: 75 |
Go and rent a U-Haul trailer for hauling a car, works good low to the ground for easy loading.
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Just don't tell them you are hauling a tractor. They have no way of knowing how much it weighs and thus can't determine if the trailer or truck is overloaded. Just tell them you are hauling a ford. They will believe that.😆
1957 WD45 dad's first AC
KMAG ![]() Orange Level Access ![]() Joined: 26 May 2020 Location: Elizabethtown, Points: 680 |
Timing is key, but visit Home Depot for truck $20 for 75 min and $60 or so per hour thereafter w/o no mileage charge. Take HD truck to local non-U-Haul place and rent trailer for $50-65/day with surge brakes or rent wireless elect brake setup if not on HD truck. While there, rent straps/chains/binder for load.
My commercial flatbed hauler is $100/hr plus tolls. IMHO, short hauls are best hired out. In PA, you can drive tractor up to 50mls on public roads for repairs/moving as farm equipment. Edited by KMAG - 06 Jan 2022 at 8:22pm |
I bet a D-14 the Home Depot truck won't have trailer hitch ball or wiring. I KNOW they don't up here in Ontario ! But call....NOT the one store you WILL get it from though....
matador ![]() Orange Level ![]() ![]() Joined: 10 Nov 2014 Location: Wyoming Points: 1727 |
How far are you moving it? I'd honestly be tempted to throw a post up on Uship or Fr8star and just see if someone will haul it for you. I paid a guy $600 to haul a WD across the entire state of Wyoming. If your distance is shorter, I think you'd spend as much on rental equipment than you would to just sit back and relax as someone brings it
Tractors: Allis WD (x2), Allis 7040, Oliver 1800A Diesel, Case 830 Caseomatic, White 2-105, Massey 1105 | Plus a Gleaner F2, 30' A-C 1300 Cultivator, Flightline bale elevator
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Good heavens I hauled my D12 over 375 miles home on an aluminum utility trailer. Couldn’t see the point of the tri axle gooseneck for something that little. Cannot tell me you don’t know someone with a 1/2 ton pickup or full-size SUV. Few years ago I needed to haul a 6080 tranny and rear end instead of plastering my trailers with road salt I rented a trailer for $85 for 24 hours from rental place. 25 years ago I hauled a 6080 250 miles behind a 1/2 ton Ram.
Edited by victoryallis - 07 Jan 2022 at 5:08am |
