Removing wheel/rim locks
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: Removing wheel/rim locks
    Posted: 05 Aug 2011 at 10:24pm
Hello everyone. I am putting new rims and tires on my D14 and had a few questions about removing the rim locks. I have tried to get them loose with an impact and didn't have any luck. I was told that if I can get them off, give them a good soaking in some penetrating oil and get them in the vise,  remove the snap ring, and then I could probably drive the pins out.  At first glance, I thought I could just remove the bolts holding the locks to the wheel center and then drive the wheel center out. Upon further inspection, my wheel centers have a groove or vee around the outside that the wheel locks "lock" into. I tried a little persuasion with a block of wood and a hammer and couldn't budge the wheel center. I don't want to hammer any harder and bend the wheel.  Whats everyone's opinions or suggestions??
Thanks!
Ben
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 10:28pm
Use a bigger hammer
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 10:33pm
Soak them in 50/50 acetone/atf for several days, meaning spray them with the mixture in the morning and at night and try to get them loose every time you spray them. Patience is the key. You can also use Kroil if you want.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2011 at 6:35am
The groove does not hold like you would think. Being you have the 8 eccentric bolts out of the center, just pound on the center dish and it will fall out. Lay the wheel down and pound down with big hammer.
Edited by Steve(SEMN) - 06 Aug 2011 at 6:37am
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2011 at 9:46am
Yep to what steve says. Remove the 8 bolts holding the eccentric bolt assys to the center, lay the tire down, outside up, place a short 4X4 on the center and pound on the 4X4 with a sledge hammer. The center, and eccentric centers will come loose and fall into the rim.
Link to a previous post on freeing up the eccentrics below:
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2011 at 1:45pm
Thanks guys! I got them off and got them all broke loose without incident! Not even a smashed thumb!
Thanks!
Ben
