Rebuilding MS TSX 464 carb
Ohio WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ohio WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Rebuilding MS TSX 464 carb
    Posted: 01 Oct 2012 at 11:37am
I am rebuilding this carb from my WD45.  Both the instructions in the rebuild kit and the parts book show small o-rings in places where there were done when I tore the carb apart.  Should put the o-rings in like the book shows or leave them out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 2:27pm
Depending on the mfr's rebuiid kit, some o-rings n' parts fit other series carburetors, so you may have a few things left over that you may not use. The best thing to do is go by the mfr's rebuilding sheet and explosion. Sometimes service manuals can make things a little more corn-fusing...
