Rear Mounted Blade Replacement Cutting Edge
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Rear Mounted Blade Replacement Cutting Edge
    Posted: 30 Nov 2015 at 1:41pm
Does anyone know where I could find a new cutting edge for my Allis blade? I believe the part number is 403578.
Thank You
Thanks & God Bless
Dennis
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 1:57pm
The last time I needed one, I got it from CAT. Bolt holes are prefect, just bolt up and it was a fair enough price.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 3:07pm
I had this question a couple three years ago for some extensions I acquired. As with Michael, I found out that CAT was the only place that carried the cutting edge that would work. Had to cut it down for my extensions and only three out of four bolt holes were in the cutting edge for the extensions, but works. There was a discussion on here about it at the time. Seems someone had a comment about a cutting edge CAT offered that was at a lower price than the one I picked up. Maybe someone will respond about that, or you could find the previous thread discussing.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 4:10pm
I got one from CAT a few years ago for my SC blade. I forget the part number and don't have time right now to search for my posts on it. Blade was only around $60 if I remember right.
AaronSEIA
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 6:42pm
Your local county road department may have some off their road graders that they consider work out. The ones around here have of lot of life left in them for your purpose
jkoby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkoby Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 8:32pm
For those that got the edges from CAT, did you go to a local CAT dealer? I am needing one for my blade as well. And $60 sounds much better than the $250 I found online.
And CAT in this case is short for Catepillar, right?
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 8:50pm
I helped a friend put snow plow edges on his Tucker Speed Mover.  They worked better than any of the worn out grader stuff.  We did have to adjust a couple of holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 9:05pm
Yeah, went to the local CAT (Catepillar) dealer. Seems mine for the two extensions was around $110. But, as I mentioned, seems there was a less expensive alternative I wasn't aware of, but was mention in one of the threads on the forum after I bought mine.
willard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote willard Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 9:43pm
do you remember did you have to take in measurements of the AC blade cutting edge and hole placement? Thank you
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 11:25pm
Earlier post with part #s
http://www.allischalmers.com/forum/forum_posts.asp?TID=23887&title=sc-blade-cutting-edge
Part #s from that post: Cat prt# 8d2786 or Cat prt# 7T-1633H, 6'X6"X 5/8
AGCO My Allis Gleaner Company
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 12:01am
they offer soft blades and hard blades, the hard ones are more expensive. the soft ones will/should out last us!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 6:24am
Another option might be to have someone weld on 'hard surface' material. Friend (who welds) did that for his snowplow blade.Just check the 'math' though, might be cheaper to buy a new blade than to have the old one resurfaced......
options, gotta have options !!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 9:05am
When I did it for my extensions, I just took the extension and the old cutting edge in. They did the measuring and I could compare with what they had on hand to get the correct one. As I mentioned, I then had to cut it down to fit the extensions.
Dave in il, how did you get the search to work so you could find that old thread. Never seems to want to work for me when I try to search. I think I also had a thread started where I showed a picture of what I was doing, but couldn't find that one either. Crazy technology!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 9:30am
I used Google instead of this sights search engine. For some reason this sight's search engine is a bit hit or miss when I'm looking for something. Google had your post with pictures listed. I put allis blade cutting edge and got 3 or 4 posts from this and some unrelated stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 9:34am
Thanks everyone for all the info. Since I have two blades I will order both parts and will post pictures and comments.
Here is the info I found off the Cat web page.
8D-2786 Curved Cutting Edges
      Part Number : 8D-2786
        $112.53 USD
Curved Cutting Edge
Description:
The best curved edge choice is often the impact tolerate through hardened edge. Curved edges penetrate the roadway better than flat edges while carrying existing material forward to leave a smooth even surface.
Specifications
Serration: Not Serrated
• Material: Through Hardened (DH2)
• Thickness: 0.5 mm
• Width: 6 mm
• Weight: 23.49 kg
• Machine: Motor Grader
Attributes:
Where impact and abrasion are low, the thinner edge provides the most economical service. Thicker edges provide added strength and wear material for abrasive or high impact applications.
________________________________________________________________________
7T-1633 Curved Cutting Edges
      Part Number : 7T-1633
          $68.55 USD
Weight : 64.4 lbs.
Non-returnable part
High Carbon Curved Cutting Edge
Description:
Curved edges penetrate the roadway better than flat edges while carrying existing material forward to leave a smooth even surface. High carbon edge offers better affordability than our through hardened steel, but has limited impact.
Attributes:
Specifications
• Serration: Not Serrated
• Thickness: 0.63 mm
• Weight: 29.33 kg
• Width: 6 mm
• Material: High Carbon
Edited by DennisA (IL) - 01 Dec 2015 at 11:00am
Thanks & God Bless
Dennis
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 2:07pm
A buddy with a Allis M100 Grader went to cat for the cutting edge, was not terribly priced either.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
