Rear axle seal leak on 6060 |
Rafterg ![]() Bronze Level ![]() ![]() Joined: 12 Dec 2021 Location: Missouri Points: 26 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Apr 2022 at 7:46am |
My 6060 rear axle just started leaking. I have read the repair manual and it looks as all I have to do is unbolt axle housing and then disassemble the axle from the housing. Just want to make sure when I slide this out, nothing drops down in the rear end.
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 959 |
Nope.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Acdiesel ![]() Orange Level ![]() ![]() Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2574 |
I have also found that putting to much grease in the fitting at the end of the axle shaft will mess up the seals and cause them to leak.
one of the guys in the shop over greased at the service and the next morning there's a puddle of oil under both axles. |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
I have replaced them on JD but just making sure nothing would fall down in the rear end when I took the axle housing off. I just split the tractor to but a new driveshaft in that broke and don't have five hours on it since doing that work.
We have detected instance of bullying in this message/comment. The person you are writing to might feel bullied. Maybe you should avoid sending messages like this. |
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
I have replaced one on my 6060 at about 9000hrs.
Make sure your vent underneath the seat is clear, mine was plugged
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8256 |
Can you please explain the being bullied part ?
I need to check that, I have noticed the last few times that when I check the oil, there is a significant amount of pressure on the plug with the dipstick.
I am not sure, every time I reply, this is added to my post.
So I am trying to locate the vent under the cab, I can see it in the book, but does it run up into the cab somewhere or does it just vent under the cab. Sorry for all the questions but just can't seem to locate it.
John m ![]() Silver Level ![]() Joined: 11 Apr 2020 Location: Wetmore, Mi Points: 278 |
More than likely just a square pipe plug looking thing that has a hole in packed with a small baffle. That's what my 190 vent plugs are.
If you lift the entire seat assembly up from the floor it is right there in the hole the seat base left i the floor. If i remember right, its a little tin crimped on cap type. I have had to unplug mine a couple times each time the axle seals quit leaking after i did that
