RC engine rebuild
GeorgeinNJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeorgeinNJ Quote  Post ReplyReply Direct Link To This Post Topic: RC engine rebuild
    Posted: 26 Jun 2012 at 9:30pm
  In the past i have seen posted a way to prime oil pump prior to starting the engine.
It was a quite a while ago so i don't recall the method. Can anyone help me on this?
I want to do this right. Thanks to all for your help, George
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 9:48pm
I usually remove the line that comes out of the torque tube and goes to the filter, turn it in an upright postion and pump oil into it with a pump oil can. I have also used a siphon pump and pumped oil into the tube. This way I can over pressure the pressure relief valve and pump oil into the cam, which allows some oil to go onto the rods and timing gears. Pump is about $4.00 at Harbor Freight. Bob
