Radiator foam kits for 7000 series
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Topic: Radiator foam kits for 7000 series
    Posted: 10 Mar 2017 at 10:12pm
Questions have been asked about these pieces. I get mine from Hy-Capacity and I,m sure that the Agco kit is similar. Actually, Hy-Capacity may supply the kit to Agco. These kits service all of the 7000 series so there are some pieces that won't be used on every tractor. In the top picture the piece in the middle goes under the air intake tube, the long pieces on the side go onto the side of the radiator,they are cut to fit the contour of the radiator and the side supports, the top pieces in the picture are for the top of the radiator. There are two different top pieces,depending on what model of tractor you have. The thicker one is for the 7000-7010-7020. The second photo shows the rest of the kit.  The pieces in the middle of the picture go in front of the bottom radiator tank. Only one is used. Select the one that is the proper length. Again,this piece goes between the radiator and the black plate that supports the air cleaner assembly. Oil cooler hoses also go up through this gap. The bottom pieces in the picture go onto the side of the air cleaner support plate. The foam blocks go into the lower front corners of the orange grille and the two small strips go between the radiator and the side support brackets. I use 3M weather strip adhesive.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 10:46pm
I made some out of memory foam. It caught on fire under the hood of the 7080. That could have been a really, really bad day. I will be checking with HI-CAP for a kit.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 12:13am
Lynn do they have the kits for 8000 series???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 7:20am
No foam kits for the 8000 series that I know of. I am not that far from their facility. I should take them some of the 8000 pieces and see if they could duplicate them.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 7:28am
Hadn't been that long ago I got a kit for my 8030.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 9:22am
Sorry, I should have said that an 8000 kit is not available from Hy Capacity. It is available from Agco.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 1:36pm
Ya I bought an 8010 one from Agco it was expensive
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 5:09pm
Has anyone tried this foam kit on a 7580?
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
This page was generated in 0.142 seconds.
