Putting a tank heater on one ninety
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 9:53am
Just wanted to report back that I did find the rear frost plug.  You can see the top half of plug in the picture.  It is nearly at the end of the engine above the starter, but there is an oil line and other things in the way.  I suppose a punch could be used without deinstalling the oil line and hydraulic lines to remove the plug.
There isn't a lot of room between the engine block and that oil line for the heater though.  The pig tail cord may be a challenge but since others have done it, it must be possible.  For now I am going to install the circulating tank heater and come back to this problem in the spring when I take the stack and hood off.
Allis sure made it a lot easier in the later models to install the engine heaters versus this earlier model.  Thanks for all of the help to those that responded.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 1:48pm
I opted to go this route for a heater on my one ninety gasser. It's soft plug second from rear, and had the two bolt holes to fasten it in. Diameter of the soft plug is irrelevant, because it just seals with a gasket against the flat surface on the block. It's been working good. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 1:56pm
To explain the peculiar looking bolt at the top, it's custom made by me. The intake manifold is in the way to where a bolt won't go in. We had to cut off about an inch long threaded part of a bolt and cut the screwdriver slot into it. We then started the nut onto the homemade bolt, then threaded the stud into the threaded hole in the block. After getting the stud bolt threaded into the block by about five threads, we tightened the nut up with a wrench. darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 2:05pm
good ole farmer ingenuity!
This page was generated in 0.067 seconds.
