Primer Pump on 190 XT
Rodd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rodd Quote  Post ReplyReply Direct Link To This Post Topic: Primer Pump on 190 XT
    Posted: 01 Feb 2012 at 7:48pm
I am looking for some ideas as to the primer pump on my 190. The old pump seems pretty well shot. would it be best to rebuilt the present one, or some better ideas used by the fine folks on the forum. I have always gooten good advise from you folks, and I thank you.
So please your ideas now
Thanks
Rodd
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:15pm
I bypass them , most leak and the fuel will gravity feed to the injector pump anyway
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:20pm
my xt has a electric fuel pump on it  cause primer pump went bad
190XT,D17and 7045
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 9:29pm
I dont remember what the AGCO cost is on one, but they are pretty high.  I have put electric pumps on a 7060 and 2 7045s because the primers started to leak and it penciled out a whole lot cheaper to put electric and a push button on the dash.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:23am
If pump advance is not adjusted with electric pimp it will advance pump at start up and idle.
  The primer kit is heigh but should last for years.   MACK
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:47am
I believe this is the part number for the repair kit 74063231. I just replaced one in August, I believe the cost was right around $30.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 9:09am
pm injection pump ed, he has the entire unit at a real reasonable price or just the plunger, whichever you need.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 10:07am
I am waiting for the plunger assemblies to come off backorder, but I do have a complete unit on the shelf. $77 plus the ride. I also have a couple used ones off pullers that could be rebuilt. these are roosa master (stanadyne) pump assemblies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 3:24pm
just checked warehouse, they now show 15 in stock, so I will be getting my order in a couple days. pm me if anyone needs the plunger assy, they are $25.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 8:21am
I hate those hand primer pumps, I've never had one last more then three or four strokes, I must be doing something wrong, but I sure don't know what it would be.
