Potential Purchase: 7580 Black Belly, questions
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 1:36pm
Originally posted by LB0442 LB0442 wrote:
Looks great, you got into it for the right price.  I have always liked the look of the big articulated 4wd.  I am glad it's not in a savage yard, good to see the big orange live on.
Freudian slip? :) lol
It is in a salvage yard technically, but we only junk out combines. :) We also do farm our ground, so it will be used on the farm.
Edited by GM Guy - 18 Apr 2015 at 8:08pm
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 1:40pm
Looks like the twin of mine.  Price was right too.  I bought mine for $1900. but spend another $3,000 fixing it up, (drive shafts, (thanks to Redline), Turbo, Hydraulic pump parts, PTO drive shaft in rear end, etc. etc.) Don't use it much but fun to play with.
Whats your serial number John? who knows, it could be! :)
We picked up 2 L3 Gleaners 2 years back that are consecutive serial numbers and almost identically optioned, seperate locations about 50 miles apart.
Edited by GM Guy - 17 Apr 2015 at 9:58pm
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 2:18pm
I should have explained that better, but the tractor is not balanced , todays standards require a static (non moving) weight of 30% rear, 70% front,or even a 35/65 and in a pull they achieve a 50/50 split, when you put these tractors on a split scale they are way to heavy on the front and light on the rear, so they need more weight on the rear to get the split right, and we did it with a half tank of fuel, figuring that would be the average. Its best if you have a scale to do it on, becasue adding weight on something doesnt always add up the way you think because of leverage, ie it would take less weight on the 3pt hitch to give you a split, becasue your pulling off the front, and adding to the rear, where as fluid, pulls nothing off the front, just adds to the rear.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 2:46pm
I don't have the SN here at home.  We've had so much rain and snow the last couple days I would have to hike into the farm where the tractor is.  Not complaining about the moisture, no, not one bit! lol
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 10:15pm
So they are closer to 80 percent on the front, and need some weight out back to put it back to proper? If so, that is pretty wild, and good to know, thank you!
It would probably be best to do some cast on the inner centers or do the 3 point weight idea. No calcium around here, especially with radials. I know its quick, cheap, and effective, but I hate what it does to rims, and IMO radials work best dry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2015 at 9:45am
I cant tell you what they are, mine came with 18.4-38 loaded with fluid, the tractor sat way to low to the ground and looked stupid, so we put on 18.4-42 radials with DA duals, we had a set here off of an 8050 that had fluid in, and we put them on the rear inside than  drove it up on the pads with the duals etc mounted, I was thinking we would need to pull the fluid out, but sitting on the scale the split was almost perfect, so we left it in, plus it pulls a 30' CaseIH 5500 SS which came from the rube goldberg school of design, and when you lift the planter it will remove all the weight from the rear of the tractor, thats why we put the fluid tires on the back of it, the split was just pure luck. They make what they call rim gaurd now, which is a non corrosive fluid, and was told by a tire dealer that fluid with no tubes causes no problems,  its the fluid that leaks between the tube and the rim that causes the trouble, he claims if you  pull a tire off of a tractor that had no tube in the rim is like brand new???  Also the debate between fluid, and cast weights could be argued for ever, I have no opinion really, but I know the manufacturesrs all want cast weights, but I believe that has more to do with them selling you pig iron for a grossly exagerated sum vs water and calcium, or rim gaurd.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2015 at 10:18pm
GM guy, mine is SN 2134, 732 numbers older then yours.  Still, they look very similar.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 2:34am
How has your 7580 worked out for you? My Dad bought one in fall of 94, black belly, loved that thing, pulled strong, never over worked it. If it was treated like a 170 pto tractor, it did well. Pulled his 30 foot Concord airdrill no issues. Got good money at his auction. Saw it one more time a year after that at a stealership, broke my heart cause no one wanted it, too small...Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 9:47pm
@Trevman,
So far so good, got to do a little tillage with the old girl last year and she needs alot of catching up on maintenance from previous owner neglect (seals, cables, oil lines, drivelines, tires, etc) but I really enjoy the smooth ride.
I bought a distant Agco cousin this spring, a 2-180 White, and I will be swapping tires around, the White blew a inside tire on the way home from the auction, the 7580 had one new BKT on a outer rear dual (IMO a new tire on a 9 bolt dual with a near bald inside is a recipe for putting all the power through the dual and tearing the center of the rim out, so it needed removed anyhow), so I will be buying another new BKT and putting those two on the inside of the White (White's engine is no spring chicken, not concerned about 18.4x38s not being able to lay down all the power, plan to use the 2-180 like a 2-135), and finding some matching used Goodyears (GY allready on it. :( ) to put back in its place.
As far as desperately needed repairs, the PTO driveline is getting alot of slack in its slip joint, and the rear main optional oil cooler started leaking, luckily at an easy to repair place. Steering hose leaking in the dash, needs a section of the exhaust manifold. needs luberfiner housing replaced due to crack. if I can find the complete spin on kit used in a yard I will go that way, but otherwise I will keep the OEM setup.
Last year's major repair was all new battery cables. I made my own, and did it up right by using heat shrink to seal up some hydraulically crimped terminals (16 ton crimper should be adequate. :) ) I converted it to stud type batteries, so I can use group 31 stud types out of the truck.
It took a little $ to get set up for making my own cables, but IMO it was worth it, and now I can do more in the future.  I am proud to say that anything to do with the cables is made in USA, and the cable cutters are too. Unfortunately the hydraulic crimpers are chinese, but seem to be decent quality.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:04pm
GM Guy, I assume that you set it up with four batteries. ? I need to do all of the batteries and cables thing with my 8550. With your crimping thing, are you going to make a business out of making battery cables for others, too. .? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:19pm
There was one for sale near here yesterday, black belly, didnt look too bad. Asking $6000 ca. Post is  deleted already, must have sold. Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 11:22pm
@ Darrel,
I am setting it up for 2, and only ran it on 1 during the summer and it started well.
I probably wont make up cables for profit...yet. might do it when winter rolls around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 12:26am
I still have the rear end of my 7080 here if you need parts/pumps
Sledhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sledhead Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 12:26pm
I have a 7580 listed for sale right now. Running unit. Just needs a valve cover gasket. Worked some fallow this spring with it and it worked great
