Painting a WC
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Topic: Painting a WC
    Posted: 22 Feb 2017 at 12:18am
I am going to re spray my WC but don't want to go the extra mile by removing the engine and gear box.
I read somewhere that a good method is to remove all the tin work and one support beam (cannel) at a time grit blast and paint the beam and the hidden areas then replace the beam and repeat the process on the other side !!
Has anyone ever used this method and if so before removing the channel where and how did you support the engine, I am guessing the wheels are left on during the operation.
If anyone has previous experience in doing this or better still has photographs I would be most grateful for any advice.
psheridan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 9:07pm
I am in the process of painting my 37 WC
I blocked up the front, removed the front wheel unit, left the angle iron to support the engine , blocked up the engine and the rear and then removed both channel irons
It is setting  there nice as can be ready to steam clean and then paint
I was not to sure of taking off both sides , but with a good stout 6x6 block system it is very stable
Will paint it with nice weather
Paul
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 2:57am
Thanks Paul
I will follow your method, sounds the way to go
If you have a picture of it on blocks it would be a great help to me
John
