OK more engine questions
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: OK more engine questions
    Posted: 29 Sep 2012 at 7:12pm
the front crank oil seal, book says newer ones have a felt and a rubber, which the one in the gasket kit has. Book says felt is a dust barrier to protect rubber seal, so i assume it would go to the out side of front cover. If so, I got a problem because the rubber seal want to roll on itself if installed that way. The one I knocked out had the felt to the inside.
OK, so in any case, now I need a new oil seal.
How do you guys feel about packing the oil pump with vasoline?
where can I get an oil pimp screen, mine is in bad shape
Do I just put a cork plug in flywheel end of crank, didn't come in gasket set
I am still confident of this;
Wait for the Lord;
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 7:33pm
Lou, keep on asking questions as I'm a few weeks behind you and I'm learning a bunch before doing mine.Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 12:35pm
bump
Wait for the Lord;
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 12:47pm
I have found when installing seals onto shaft if i take a heavy flexible plastic sheet like a page protector (clear plastic) and wrap around the shaft , then lube it well and slide seal down that tube of plastic I can avoid damage to the seal from keyway or rough area of shaft. It also allows the lip of seal to open up and slowly stretch to its proper size and fitment.
 Unsure if the crank has a oil wick in the rear for oil to flow to pilot bearing ? I know on the HD5 -2-71 they used this method for oil , I plugged the hole after removing felt wick , put in a sealed bearing and have had no problems with oil leaks or bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 12:58pm
If you haven't done it already, you need to line the front cover up with the shaft. There are several ways to do that, indicator or turn and bore something to about .002 smaller than the seal bore and .002 bigger than the crankshaft. Put that "line up tool" in place before bolting the cover up and it will be close enough.
 I have used a piece of .010 shim stock, either plastic or brass to roll up kinda cone shaped to allow sliding the seal on as Coke suggested. The rubber seal should be angled in toward the crankcase, keeping oil in and yes they can be tricky getting them on the shaft. Make sure it is coated in sompin slipperdy before you push it on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 7:21pm
I put rubber seal in  bore and (lubed) worked lip over crank with small screwdriver.Then used the "feel" method to center.Drove felt seal in last with a piece of pipe(I think that's what I used). Dad did scores of em with the 'feel" method. Never seemed to be a problem.He did mine around 1982 at O/H and it was still working until 2 yrs ago when I put a crank in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:02pm
Well, again guys you come through. My son machined a spacer to center the cover.....I haven't seen it yet. I assume the seal goes on rubber first, felt last. I think part of my problem was trying to seat seal in cover first and then installing cover.
Anyhow, how do you guys prelube the oil system? in my chebby days I just used an electric drill and an old distributor shaft, but that wont work on the AC 226 engine. Vasoline packed in the pump was an old trick.... any thoughts?
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:37pm
the pump is submerged in the oil so if it can't pick it up.........I suppose you could leave the line off the block where oil goes to filter and crank with out plugs in til some comes out. I doubt you will have a problem.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:56pm
I use a canister filled with oil hooked into the block that feeds the bearings then force the oil with air to feed bearings. Then oil pump has time to prime without the bearings being deprived. Plus you really get a feel as to how free the engjne is when its on a hydroscopic oil wedge as it is when running verses wrench feel and molylube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 10:04pm
Packing the oil pump with vaseline isn't the best idea. When the engine fires, where is that slug going to go? On an engine that runs in the 10 to 15 psi range, you're potentially restricting oil flow to the bearings. Mitch's idea is how I prelube all engines. I got a pre lube tank from O'Reilly Auto Parts years ago when I bought a long block from them. I lost the receipt so I was never able to take it back. It's gotten used enough now it's no big deal. By forcing the oil in through the oil pressure port, or any place you can tap into the oiling system, it fills all of the galleries, including the oil pump with oil. It also works extremely well to fill the high pressure oil system on 6.0 Powerstrokes.
