Oil leaking from spark plug |
Owen in KS
Topic: Oil leaking from spark plugPosted: 19 Jan 2019 at 1:33pm |
Hey all,
I have a ‘63 allis chalmers d12 series II. Noticed that oil is leaking out of where one of the spark plugs is. What does this mean? What part(s) do I need to fix it? Also, I am looking to buy an engine oil dipstick for the same tractor but cannot find one anywhere. Know where I can get one? Thanks. |
Alvin M
Posted: 19 Jan 2019 at 1:49pm |
late D14 all D15 use the same one 70231188 countryside tractor in PA has used ones 717-923-0421 or any other used parts place
Owen in KS
Posted: 19 Jan 2019 at 2:48pm |
Thanks for the info on the dipstick!
Any idea about the oil coming from behind the spark plug? |
Alvin M
Posted: 19 Jan 2019 at 2:57pm |
check head gasket real good and value cover oil would not leak out of spark plug clean real good then run tractor and watch to see where it leaks
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54385 |
Posted: 19 Jan 2019 at 6:16pm |
Bad valve guide might be leakin into the cyl, and being forced out at malformed SP threads is a possibility. Take the SP out, and see if it is oil fouled, and condition of threads. Most likely VC gasket, though...
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 19 Jan 2019 at 6:39pm |
Had a couple people thought they had a head gasket because of dirt collecting in wet oil around two spark plugs. Turned out to be a valve cover gasket. No dirt above the plugs. You wipe your thumb above the spark plugs and your thumb would have oil on it.
Gerald J.
Posted: 19 Jan 2019 at 8:58pm |
I think the valve cover gasket would be the most likely problem. My dad's first new car a 1954 Ford with an overhead valve inline 6 leaked oil down the back of the block. The dealer replaced the gasket but that didn't cure the leak. My dad attacked the casting with a flat file where the factory hadn't flattened a rise in the head casting, and it didn't leak for the next 100,000 miles. That was an engine where the valves were supposed to be set every oil change and set while the engine was idling.
So it cold be the gasket or a roughness on the head or the valve cover above the spark plug. Gerald J. |
