off color ques. how much HP for Kinze
orangepower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepower Quote  Post ReplyReply Direct Link To This Post Topic: off color ques. how much HP for Kinze
    Posted: 06 Jul 2012 at 12:12pm
How many HP's to pull a Kinze 8/15 no till planter, would 110 hp mfwd do it?, do I need a set of duals, has 18.4 38's on rear.
45 diesel puller, 45 gas puller, ca puller
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 12:42pm
We used to pull a 6/11 kinze with a 6310 FWA John Deere, which is about 90 hp. We pulled it in the hills and got along fine with singles.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 12:45pm
orangepower .... easy  pullin ....
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 1:11pm
Guys used to pull 12/23's around here with 1066 IH's. I've been told they pull very easy. Currently looking for a 12/23 myself. Planned on pulling it with an 2wd 8070 but could use the D-21 or 220 in a pinch.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepower Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 2:09pm
Crysorry to say I have a JD 6615 fwa was afraid it would struggle with it
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 2:42pm
We have, well, we had a 12 row Twin Line until we traded it recently. We pulled it with a variety of tractors, including a AGCO RT150, AGCO DT200, MF 2745, and we even used a friend's AC 7000 one year. The way I heard it, that was all the 7000 wanted, but it pulled it. I think you'd be fine with a 110 hp FWA.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Roger D Slaughter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger D Slaughter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 9:24pm
           i pull  my  8/15 kinze with my 7060 in hill ground with no probem.
nevin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 12:50am
You don't NEED duals to pull it, but I would certainly say it's a good idea.  You always want to try to spread your weight out when you're pulling something like that.  How much tongue weight does this planter have?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 4:49am
pulled an 8-38 planter in our hills for years with my 180D....plenty of power!
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 4:37pm
duals would be a good idea, like nevin said to balance the weight and more traction in hills & wet sopts.  we pull a 8 row kinze with interplants with a 7045 w/duals.  it handles it about right, but you know it's back there when u got the bean units full n pullin a hill!  also when transportin, i don't run quite wide open cause it can get the draw bar bouncing about like if i take our 600 bu. grain cart 2/3's loaded on the road.  as u know 4wd makes a heckuva difference.  i'd say you'd b fine but go with duals.  good luck
