No-till coulters on a 74 planter?
allispicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Topic: No-till coulters on a 74 planter?
    Posted: 15 Mar 2019 at 5:47pm
I have a 4 row model 74 planter and I’m trying to figure out if no-till coulters were an option. I’m going to be no-tilling beans into pasture ground and think a coulter ahead of the disc openers will be necessary.
Thanks
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 6:01pm
What frame do you have? 74 is a planter unit. No till work some frames but not all frames
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 6:29pm
Unless it was a No-Till special planter, the no-til coulters were an option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 8:14pm
How do I tell what frame it has? It is a pull type planter with hydraulic cylinder to lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 9:28pm
One hydraulic cylinder ?? and only a two-bar frame?? That planter wasn't really designed for a no till coulter. The planters with 3-bar frames used the no-till coulters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 6:56am
It’s a 2 bar frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 7:04am
I'm not saying it hasn't been done, but that frame is light and may not keep the coulters in the ground in true no-till conditions. That frame was made for fertilizer on the front bar.
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2019 at 11:54am
We planted no-till with a 2 bar frame for years. The 74 units on the conventional planters and the no-till ones are the same the only difference is the frame.
We had two 55 gallon drums full of water mounted on ours for extra weight to make it go in the ground.  Sometimes if the ground was real hard we had to hang a couple of extra 100lb suitcase weights on it to make it go in the ground.
If you do it, use the thin fluted coulters, the bubble coulters and the wavy ones are much harder to get into the ground.
You will also need the no-till tires with the center rib if your planter units don't already have them.
Edited by VAfarmboy - 17 Mar 2019 at 12:10pm
This page was generated in 0.250 seconds.
