No Narrow Front B's |
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Topic: No Narrow Front B'sPosted: 28 Jan 2012 at 8:13pm |
For some reason I never thought about it until I read a post tonight about seeing a single wheel B. Some one corrected them saying it was probably a C. I then realized I never saw a NF B before. I take it A/C never made one. Seems odd for some reason.They made every other model either way.Or am I wrong.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 960 |
Posted: 28 Jan 2012 at 8:16pm |
There was a narrow front "B" at the GOTO in Union Grove 2005.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Denis in MI
Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
Posted: 28 Jan 2012 at 8:22pm |
I think the reasoning is that a B would have been awful limited on row spacings with a narrow front end.
Just my opinion, Denis |
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 28 Jan 2012 at 8:34pm |
I have one, until Steve and I rip the early C front end off it and put it back on his tractor where it belongs...
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Brian G. NY
Posted: 28 Jan 2012 at 9:42pm |
There were a few made..............but not at the Allis Factory.
Like the C tractor on e-bay now with the B arched wide front, it was real easy to
split the Bs and Cs and switch halves.
Tim8975
Joined: 05 Sep 2011 Location: Clarksville, MI Points: 37 |
Posted: 28 Jan 2012 at 10:07pm |
The Model B was designed and marketed as a single row crop tractor whereas the Model C was wider and designed and marketed as a two row crop tractor. Only makes sense that a narrow front end on a single row tractor would not work out. Tim
http://www.allischalmershistory.com (Work In Progress)
1959 AC Series 1 Black Bar Grille D17 Gas WF |
DREAM
Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Posted: 28 Jan 2012 at 10:38pm |
Yeah, what Tim said. I believe DickL has one, but it is a sister to the one Glenn has(meaning it has an early C frontend under it). Bs and Cs had several differences, despite sharing engines, hoods, transmissions, and some other components. They had different finals, different hubs(on earlier models), different fenders, and the radiator shroud. Also, the steering boxes were reversed. If you put a B steering box on a C, the wheels would turn left when you turned the steering wheel right. Would be vice-versa if you put C steering box on a B. Some folks found this out the hard way. That is one obstacle to overcome when making a NF B. You would need to change the steering box as well as the front end from the engine forward. |
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 28 Jan 2012 at 10:44pm |
There was NEVER a factory made narrow front B. However, some have taken a C narrow front or single front and put it on a B.
As said above the B was a one row tractor. Good Luck! Bill Long |
