Need quiet muffler for wd45 tractor
case310350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote case310350 Quote  Post ReplyReply Direct Link To This Post Topic: Need quiet muffler for wd45 tractor
    Posted: 13 Jun 2018 at 8:38pm
Looking for a muffler that will be much quieter that the original.  I see nelson is popular but is it quieter?  also need air cleaner to carb hose.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 9:19pm
quieter than what ?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 10:52pm
If you still have the old hose, take it to a good auto parts store.  A non chain type store is better.  If you're nice they will find a hose that has a piece shaped like you need that you can cut out of it.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 6:37am
Steiners has the carb to air cleaner hose. Site sponsors on here probably do as well
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 7:14am
The old Nelson is maybe slightly quieter than a cheap stanley but if you are looking for real quiet then an oval muffler is much better and there again a nelson is quieter than a cheap stanley. An oval, of course won't fit your hood unless you cut it out or you extend the pipe above the hood.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 9:35am
I cut the oval in the hood and installed  D17 oval muffler (requires pipe manifold) and that was great till the vibration broke out bottom. Back to a Nelson with ear plugs. Not the main tractor anymore so not much drive time.
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 9:37am
go to Agco and get one same price as Steiner or DJS
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 3:37pm
Have a muffler shop built you a pipe that comes up thru the hoods hole and bends forward horizontally towards the radiator. Connect a D-17 series 4 muffler to that and lay it horizontally directing the noise out in front of you. Support the muffler with a bracket of some sort to the hood or side frame. It will be quiet in the seat.
This page was generated in 0.146 seconds.
