Need ideas how to free up bearings
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: Need ideas how to free up bearings
    Posted: 01 May 2017 at 8:45pm
I have a old Deere planter and the disc openers are rusted and won't spin
I have sprayed them with Pb blaster, and heated it, no luck.
Any help would be appreciated.
Mack hopefully you see this, you always seem to have answers for my questions. I can't thank you enough
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 9:17pm
If they have bushings, press them apart, clean them up, oil and put back togather. If they have bearings, best to replace bearings. A rusted bearing cleaned up and oiled has a short life.      MACK
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 9:34pm
Depending how rusted the bearing is I have had luck with some IH disc harrow bearings. Drill a very small whole in the seal and add grease,fill whole silicone gasket maker.  Pulled with a crawler so never over 4.5 MPR. Planter bears should be much smaller and cheaper so new may be a much better deal to just put new on.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 9:49pm
What JD model number I may have some bearings for it
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 9:13pm
I thinks it's a 494
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 8:23pm
I use JB 80 Menards has it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 9:11pm
yep...squirt sum JB80 on them, go have a cup of coffee and come back to them
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 7:49am
soak in diesel fuel then try to work grease in after freed up, but as Mack says they wont last long
This page was generated in 0.075 seconds.
