My weekend purchase
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Topic: My weekend purchase
    Posted: 02 Apr 2012 at 8:35pm
Went to an estate auction in Pilot Grove, MO on Saturday and "accessorized" my One-Eighty gas.  Notice anything different??? lol!
Picked up this Westendorf TA26 quick-attach loader.  It was on an AC 185 but the loader was sold separately.  Bucket is in great shape, pins look real good with no noticeable wear, no cylinder leaks, self-leveling bucket option.  Rated for 3000lbs working capacity at 2500 psi.  Had a minor bit of welding around top rear pins with some heavy angle iron welded to strengthen the top arms (need to paint that).  No bends or breaks anywhere else in the loader for mounting brackets.  Bolted right up without any problems (I had to remove my chin weight and two slab weights).  Plumbs into the rear remotes.  I think I got a good deal for $1900.  I plan to  upgrade the old 7.50X16 fronts all the way to 10.00X16.  That's what the 185 it was on had.   I just need a set of pallet forks for it now.  I'll weld some gussets too between the front spindle carriers and the axle frame.
Auction also had a DA 7085 that went for about 12K I think?  AC 6080 2WD with a 460 loader went for $9800.  It was rough - grill smashed, hoods had damage.  They had an issue with the key switch shorting but sounded good when started.  The 185 the loader was on needed ether to start in 80+ degree weather and was rough looking but sounded good when started and had good tires.  It went for $3250.  There were some AC suitcase weights...went for about $40 each.   Two stacks of 7000 weights I think and one stack of 175/185 ones.
I picked up this engine stand for $20:
I also got these 185 front weight brackets for $20 each  :-)
I bid (but didn't win) on a few other things like some spare Gleaner parts and a set of lift arm latches (HD, one good, one bad) they went for $40.  Like all auctions, some stuff went reasonable, some cheap, and some high.  It was the first auction for my two older sons (Lucas - 11 and Ethan - nearly 8) and Lucas in particular thought it was very interesting.
A few more pics here:
http://s39.photobucket.com/albums/e176/Skyhighballoon/2012%20March%20Farm%20Trips/?start=all
Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 8:44pm
I saw that sale bill and thought about going, It looks like those were the 200 210 weights if so 40 ea was pretty cheap, I bought 2 complete sets about 2 weeks ago and sold one set (yes I actualy sold something allis, But I got enough $ out of the one set I had to )
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 8:52pm
Mike,
Ya hit a home run there buddy! Congrat's on your new additions! That loader is the best thing since sliced bread! Good deal on the engine stand too.
Steve@B&B
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 9:11pm
Way to go Mike! You did good.
 Want to let you know that I have a 10.00 x 16 4 rib tire here that I won't be needing or using. I got it ahead of my 19 coming home that didn't make it.
It has a plug in it.
$25 + ride and it's yours. Jim
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 9:00am
Don't abuse my "favorite" tractor now.  LOL
That should be a good matchup.  Enjoy!
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 11:28am
Good deal Jessie!!   LOL .
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 8:48pm
hold on to your hat!!! bought a new 10.00x16 tire today $190.00
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 7:14am
That is a really good deal - would like to have that set up on my 185  - lucky dawg.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 7:50am
Mike I got a good used set of 1100 x 16" tires and wheels for the 4020 for $85.00 from Cook tractor over at the combine side. Maybe you can find a set there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 8:47am
You might want to mount brace's from loader to the back axle on both sides if you are going to Bulldoze with it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:12am
Fred - no plans to treat it like that at all (got to keep Brian happy, lol!).  My farming partner has two CAT 246 skid loaders, a good sized CAT track hoe and a CAT D5 dozer among other things if we need to do any serious earth/rock moving.  I'm working on a set of pallet forks for it now and they will get used more than the bucket.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
