Model G timing help
pungobob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pungobob Quote  Post ReplyReply Direct Link To This Post Topic: Model G timing help
    Posted: 30 Mar 2023 at 8:40am
Good morning all. I need some clarification on timing my G. The service manual is a bit vague to me on exactly where the timing mark should line up when setting the distributor. Should the timing mark on the crank pulley be at 12 o’clock or 6 o’clock when the #1 piston is at TDC? I’m sure I am making it more complicated than it really is. Thank for any advice.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2023 at 9:31am
should be at 6 o’clock, sometimes I have to look at the hole below the crank start hole to remind myself if the back cover is off, remember #1 is in the rear!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote pungobob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2023 at 9:50am
Thanks Joe. That’s kinda what I was thinking but thank you for verifying that. Thanks for the reply.
