Milling vise |
Page <12 |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9733 |
Posted: 01 Feb 2023 at 9:27am |
One of my old drill presses has holes all over the table. I need to try this. I bought my first drill press in 1994. I was fairly young then some years later I bought a drill press vise. Neither of them have one single hole drilled in them. My other drill press I bought used with no Motor. The table on it was full of holes. |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 01 Feb 2023 at 6:29pm |
I've done that... and I've had machines with holes drilled elsewhere that I didn't want, and I fixed 'em in other ways... like... find an appropriate sized tap, tap it for threads, red-loctite thread in a screw, saw it off 1/8" proud, then give it a quick 'kiss' with 4" grinder and flapdisk... then paint! ;-) Battle scars happen, particularly with vises. It's like... us... as we work, we wind up with cuts and bruises, scrapes and scars... missing toes, chipped teeth... but unlike machines, we can't be carefully worked back into pristine condition, we're just condemned to be ugly curmudgeons overweight with experience, and shops full'a tools we never use, right?
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 01 Feb 2023 at 8:23pm |
HMMmmmm,,,, Dave Kamp and Steve,,,,,y'll are giving me some ideas , you are,,,,!!
Edited by desertjoe - 01 Feb 2023 at 8:24pm |
Joined: 11 Sep 2009 Location: illinois Points: 90904 |
Posted: 01 Feb 2023 at 8:27pm |
most of your "HOLES" see to be on the top of the movable jaw !! You can fill them, then PAINT and no one will know... Normally the holes are between the jaws in the frame rails... that area is not painted, but the JB fills in well.
desertjoe
Posted: 01 Feb 2023 at 10:43pm |
Hey Steve,,you and ole Dave gave me some great ideas,,,,ole Thad ain't gonna recognize this vice when he opens the box,,,,,, ![]() ![]() ![]() And,,and,,,he gonna be ready to fight someone that wants to borry it,,,,,
![]() Edited by desertjoe - 01 Feb 2023 at 10:45pm |
DaveKamp
Posted: 08 Feb 2023 at 6:17pm |
desertjoe
Posted: 13 Feb 2023 at 11:35pm |
Well,, you guys take a gander at this tool and tell me if ole Thad might like it now,,,,,? Just goes to say,,,a little amount of elbow grease will do wonders with good quality tools that have suffered some abuse,,,,. That JB Weld will work wonders and will also hide a multitude of sin.,,,, ![]() ![]() Only'isr thing is now to figure how to get this heavy sob into Thad's hands,,,,just weighs 53 pounds,,!! Don't believe I'm gonna send USPS,,,, ![]() CHIT,,can't get it tp load the pics,,,chit,,!!
Edited by desertjoe - 13 Feb 2023 at 11:43pm |
Thad in AR.
Posted: 14 Feb 2023 at 4:28am |
Text me the pics. Iโve learned how to load them from my IPhone.
You could always haul it up here. Iโd even take you to lunch at Sauced.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35705 |
Posted: 14 Feb 2023 at 4:59am |
Learned years ago to
Situate spacers under the worked piece, a scrap of leftover steel or aluminum even wood or plastic, sacrificial just to prevent holes in sensitive tables or equipment. |
desertjoe
Posted: 14 Feb 2023 at 12:12pm |
OK, Gents I been doing an fbi on all the how to's on the web and since I have a new IPhone 14 Plus,,,it IS different than my old IPhone 8 and takes a somewhat different method to transfer pics from IPhone to PC,,BUT, BUT,,,"NOT" to transfer to the ICloud as I do not like the idea of having my pics on that cloud because it establishes a "line" from it to your PC, ,,,. SO, I wanted my pics to stay on my hard drive where I can then transfer to my External hard drive at my leisure ![]() |
desertjoe
Posted: 14 Feb 2023 at 12:16pm |
desertjoe
Posted: 14 Feb 2023 at 12:17pm |
DMiller
Posted: 14 Feb 2023 at 12:39pm |
Appears an old Milton
Posted: 14 Feb 2023 at 12:48pm |
WOW......... thats PURDY !!
Thad in AR.
Posted: 15 Feb 2023 at 3:37am |
Wow that looks too good to use.
Purdy. |
desertjoe
Posted: 15 Feb 2023 at 5:46am |
Well, I Thank yee, Guys,,,!! That JB Weld is super great stuff ain't it?,, Don't have an idee how old this tool is but the ways are perfect and just as tight as a youn,,,,er,,,never mind!! You can spin the jaw handle with one finger just as slick as,,,,well,,there I go again,,,, It does have a tiny lube hole for the jaw screw and wonder if there was ever a oil chingas there? I may try to machine a press fit plastic plug or maybe brass to keep trash out of that spot,,,? The weight of this thing is really impressing me cause you DO NOT want to have to move this behemoth more than once a year,,, 56 Lbs of heavy iron!! Now,, getting it to ole Thad is next challenge,,,,,
DaveKamp
Posted: 15 Feb 2023 at 7:14am |
Nice cleanup, Joe! In a typical shop, a guy would put a drop or two of way oil (like Vactra) in that lube point, and a little on it's ways and leadscrew... mebbie every time or two that they oiled any nearby machine's manual lube points. They'd also put a little on any nearby chucks and tooling... then move on to the next work bay. One of my (now long passed) buddies started at IH as the 'oil cart' guy- he pulled a wagon with a barrel and hand pump, refilling oil cans and topping the Bijur automatics' reservoirs... once a day, from one end of the wing, to the other, and back. Guys on the line would stop the machine between parts just long enough for him to get in there...
desertjoe
Posted: 15 Feb 2023 at 6:55pm |
Well,,,seeing as I gots Dave Kamp's stamp of approval along with everybody else's,,,I'm OKAY,,,,!!! Hey Dave K,,, Now that I'm done,,,do I get any of that money back,,,,๐๐
DaveKamp
Posted: 15 Feb 2023 at 9:12pm |
Well, I think three orders of JB Weld might still be more expensive than a dozen eggs...
desertjoe
Posted: 15 Feb 2023 at 10:07pm |
Well,,talking about them EGGS,,,my chickies is still out on strike and not laying yet,,,so I had to go to Walmart to get some eggs,,,,,,,and,,,,I started to think them must be selling golden eggs,,,!! finally picked out some extra small eggs and they was $7.49 a dozen,,,!!! I know them chickies is going to hear from me in the morning,,,,,you just wait,,,,,,,
Thad in AR.
Posted: 16 Feb 2023 at 4:08am |
Joe where do you get your feed?
A friend was getting feed someplace (TSC) I believe but canโt remember? Changed feed and they soon started laying. |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11419 |
Posted: 16 Feb 2023 at 11:50am |
Had a friend that put a light on his chickens and they started laying
DaveKamp
Posted: 16 Feb 2023 at 10:17pm |
Our new flock started laying about three weeks ago. First we got one... then two... then four... Yesterday we got 14 eggs. Today we got 15. There's only 16 birds... I turn on the inside light (with a remote control) at 6:15am, and turn it off at 10pm. Watering trough runs 24/7, so always fresh (and not frozen) water. I keep the food bin stocked. We go in to check the hens, turn on the big overhead light, and fill the food bin around 7:15am, and check for eggs when we get home around 5:30... I add to the food bin then, and turn off the big light... but leave the light inside the pen on 'till 10. It's been around 34F in there for the last two days, but it was up to almost 55 several days ago. It'll be down to 11F outside by 7am tomorrow, mid '20's Friday night, and get above freezing by 9:30am Saturday, should stay above freezing save for a slight dip below each night 'till THursday next. Considering how they've done so far, I don't expect the upcoming variation to have any impact on egg production...
Page <12 |
