Matching Used Camshaft and Lifters
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 2:54pm
well... a guy could chuck them in a cordless drill, clamp it in a vise, duct-tape the trigger ON, and use a fine, well-worn flap-disk in a 4" grinder...
Or better yet, put a cheap speed controller on the 4" grinder, dial the speed way down, and smear the worn-out flap disk with some fine valve grinding garnet mixed with axle grease....
making them convex and PRECISE is simply a matter of having a radius to work on...
If you were a Kiwi, you'd cut a broomstick off at whatever that convex radius is, mark a spot on your shop floor just below where your cordless drill chuck spins, and use that as a 'swinging radius' rest for your 4" grinder as you made that dressing pass...
..If you were a Scotsman, you'd find a much harder way to do it...
...and if you were Russian, you'd mix some vodka with the grease, and post a how-to video on Youtube!!!  LOLLOLLOL
(This, by the way, is a tip-of-my hat to all the Kiwis, Scotsman, and Russians out there who live amidst, and solve real-world problems and are NOT encumbered by the Proper Gentleman's Rules Of Machine Rebuilding Propriety (PGROMRP)
Edited by DaveKamp - 16 Jul 2020 at 2:59pm
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 3:15pm
As a not-motor guy, I am not quite sure what I am looking at. Is this something that yields motor "clicking" when running? Or some other "noise"?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 6:12am
A hollow or wore lifter will increase the camshaft lobe ware to decrease the opening of the valve.  Valves not opening will decrease fuel entering the firing chamber as well as allowing proper exhaust which can cause burning of a valve. If you only using the tractor for puttering around you most likely will never know the difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 8:02am
I had a B&S Vtwin Intek apart the other day and gee, when you consider it runs at 3600RPM for hours, weekly, the 'valve train' is well..kind of a joke compared to a 'tractor'.
I'm thinkin you could 'mismatch' a tractor valvetrain and never notice anything chuggin along at 1500-2000 rpms....
While it would be nice to properly rebuild and get it 'tight' and up to 'factory specs', overall, it probably doesn't really matter....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 11:39am
In most cases today for sure. 10 hours a day on a plow or fitting ground in making a living with a tractor that is less than full power would make a difference and make for tiring days.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 6:08pm
I'd be shocked if AGCO even has any available.
Turns out they don't, but I lucked out and my dealer has a NOS one at a different location that I'm supposed to pick up next week when it comes in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 6:10pm
This engine wasn't making any odd noises and ran pretty well. I think it must have had almost no oil pressure or got a bunch of junk in the cam area at one point because in addition to the worn lifters, the camshaft journals were also very worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 6:21pm
I have to admit I'm not ballsy enough to try any of these, which may mostly be me overthinking it combined with not having enough nice ($$$) equipment... I sure couldn't meet the radius that is presumably specified on the print from AC. Or, it could be too much German in me vs. the Scottish. We will see what the new part looks like when it arrives and I'll proceed from there.
Certainly spinning the lifter while removing material is the way to go. The chuck on my valve grinder won't quite open up enough to fit these. I've been drill press shopping for other reasons already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 11:30pm
I picked up the new lifter today and it is actually very flat - not at all convex. Unless AGCO changed this more recently for service parts, I assume this is how they came from the factory for at least the 201 engines. As Butch said these engines should be happy with flat lifters - that appears to be how they were designed. I will use the valve end grinding attachment on my Sioux and clean up my old lifters with a nice flat surface and be able to sleep at night.
I am thinking that I will call around and ship my camshaft out to have the lobes reground. Jacob's right - not worth risking it at this point with the rest of the money I am putting into the engine. A couple lobes have enough pitting that they definitely need attention. Hopefully it will be good for 40 or 50 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 5:43am
I will stand corrected! I received the convex information from the shop that did my crankshaft grinding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 5:49am
John,
 Good information! Thanks for sharing. It is nice to have the real part in your hand to get good data from.
Nice picture! Get that old cam tuned up and you will be good to go. Hey I way over think stuff too. Then have to get a reality check when I actually have the items in my hand and the work needs to get done! German and Swedish on this end.:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:00am
Well, that's not to say that the B/C/CA engines didn't have convex lifters, but I would be surprised if they were any different. Convex lifters seem to have been very common in automotive engines which is probably why the machine shop said that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:05am
John,
No problem Chris. I wanted to solve this mystery. Thankfully they should be easy to clean up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 8:42pm
I wanted to follow up after resurfacing my lifters in my Sioux 645L valve grinder/resurfacer. I used the valve stem end attachment and took a bunch of light passes to get to a completely new, flat surface. The company I sent my cam off to (Delta Camshaft in Tacoma, WA) could've resurfaced them for several bucks each + shipping but the guy there I talked to said this method would be good for anything like this WD engine that has flat lifter faces. Anything with convex lifter faces (i.e. most automotive applications) would probably need a special tappet/lifter grinder that can give you a consistent radius, and I'd have to send those out to a shop like them.
My valve grinder was in need of a new end wheel, which was about $30 and should last me through a lot of lifters and valve stem ends. I figure it has paid for itself already. I still need to put the engine back together and hope this was a successful project, but I learned a lot about lifters and camshaft grinding between the forum and Delta Camshaft.
Very worn lifter as removed from the engine:
Showing the attachment that holds the lifter, which is rotated up and down in and out of contact with the grinding wheel. Then you slowly turn the red wheel in the lower RH of the picture to feed the lifter closer to the grinding wheel with each pass, to take more and more material off of the face.
Here you can really see how the lifters had worn so that the face was concave - the freshly machined surface is a high spot only around the outer edge, where there is no wear from the cam lobe:
And done:
This page was generated in 0.316 seconds.
