magneto spark
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Topic: magneto spark
    Posted: 27 Sep 2016 at 3:46pm
Should a magneto spark turning by hand on bench? or does it need to turn faster?
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 3:51pm
Mine will spark when turning it by hand. They came out on a lot of hand crank engines, so they should spark even when just turned slowly. If the impulse is working.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 4:00pm
That's what figured. This is my first mag rebuild. I replaced coil, condenser, points and insulated wire from points to condenser. I don't get any spark on coil wire against mag housing when turned by hand. I'll take apart again and check everything again.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 4:02pm
It should turn hard then snap and make the spark. If not the impulse isn't working.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 5:00pm
What's the make and model of the magneto your working on?
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 8:05pm
Remember, only one plug will fire on each turn.  Not all will fire.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
