magneto spark |
Sam T-Ga ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Monticello, Ga. Points: 392 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Sep 2016 at 3:46pm |
Should a magneto spark turning by hand on bench? or does it need to turn faster?
DaveSB ![]() Silver Level ![]() ![]() Joined: 04 Aug 2012 Location: mocksville, nc Points: 243 |
Mine will spark when turning it by hand. They came out on a lot of hand crank engines, so they should spark even when just turned slowly. If the impulse is working.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
That's what figured. This is my first mag rebuild. I replaced coil, condenser, points and insulated wire from points to condenser. I don't get any spark on coil wire against mag housing when turned by hand. I'll take apart again and check everything again.
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
It should turn hard then snap and make the spark. If not the impulse isn't working.
Gerald J. |
Matt (Jordan,MN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Jordan, MN Points: 3808 |
What's the make and model of the magneto your working on?
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
Hubnut ![]() Orange Level ![]() ![]() Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Remember, only one plug will fire on each turn. Not all will fire.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
