Loud Wheel Noise (AC WD) |
Author | ||
Knight63 ![]() Bronze Level ![]() Joined: 28 Jun 2012 Location: Hemlock,MI Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Sep 2012 at 7:54pm |
Hello, I'm quite new to tractors so this might be a stupid question. My WD's wheels make a lot of noise compared to other tractors I've been around. Is this normal? Does it just need some oil or grease? Thanks
Sponsored Links | ||
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Depends on the noise, a common cause of wheel noise is loose eccentrics on the spin out rim, another possiblity is a damaged final drive. Can you give a little desription of the type of noise? Metal on metal grinding? Squealing? Clunking? And approximately where is it coming from? |
AGCO My Allis Gleaner Company
dt1050 ![]() Orange Level ![]() Joined: 05 Jul 2011 Location: central pa Points: 1078 |
which wheels?
I'm pretty sure its both wheels and it sounds like the gears in the wheels. The noise gets louder as you go faster. I'll take it for a ride later to be sure. My dad and brother just think its the way the gears were designed and aren't concerned by it, but none of us have ever been around another WD to know if its normal. Thanks
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
The rear end of a spur gear WD transmission will howl and that's the nature of a spur gear tranny. Olivers are even louder IMO.
Wink I am a Russian Bot |
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
WD final drives are notoriously loud because of the straight cut gears. drop the pans on the bottom of the final drives and make sure they're not full of tar, or empty. it is common for the gear lube to never be changed or level checked. clean out the pans really good and put them back on with new gaskets, then fill them with 85-140 gear oil through the side plug until it runs out the hole, should quiet them down some.
Thanks a lot for the help everybody. It is greatly appreciated. I won't worry about it anymore.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If you don't take Bills's advice and clean and inspect the finals, I would at least take the plug out and see if there is any gear lube in them. If the noise leads to worn bearings and shelled out gear teeth, it will be painful to fix later.
MikeinLcoMo ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: west plains mo Points: 620 |
Last time I heard a loud noise from a rear wheel was when I backed over the Brother in law's foot while he was giving driving advice.
sounds like his fault he didn't give better advice ![]() ![]() |
Edited by dt1050 - 07 Sep 2012 at 4:11am |
dannyraddatz ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Plainfield, Ill Points: 848 |
Bill, I used 80-90 wt. oil when I did my finals, my AC book called for 80ep. Why do yo recommend 85-140 instead? Second question, where do you buy 250ep oil for the steering gear box? Danny
Danny Raddatz
85-140 being thicker seems to quiet it down a bit more, also sticks better to the gears and makes it up to the pinion better and doesn't leak as easily. since I only use mine in the summer I don't worry about such thick oil in the cold. can't help you on the steering gear oil I haven't worked on mine, I think there was a post on here a while back about it maybe try a search
Edited by Bill_MN - 07 Sep 2012 at 10:04am |
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
I have never been able to find 250 wt oil. I just put in a grease fitting and use grease. It does not leak past seals like gear lube does.
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
80/90 or 80/140 for a WD sounds good to me, when I did my WC it called for 250 -- was unable to find any so made up my oun concocktion mixing chasis grease with 80/90 till it was almost as thick as sheet rock mud.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6069 |
When it sticks to the gears really, really well, you can pull the pan right off, and it still won't leak out!!!
Of course, if 'ya get dirt in that stuff, it just turns into an abrasive grit and wears the teeth down too... but I'll third Bill's advise to check 'em out. They may be a little noisier than normal noisy on account of it being ill-maintained. Good idea to drain the transmission and refill it, and also replace the stick-shift boot, as the boot tends to rot away, and rain runs down the stick into the transmission case, and you wind up with all sorts of wonderful things as a result. Like... going out to start it up on Christmas Day, and find that the transmission is totally seized... frozen full of water... and the case is cracked... |
Has anyone ever used Lucas oil products or additives? I had transmission problems about 50,000 miles ago in my suv, when the transmission fluid was changes they added a lucas product. That transmission is still running strong at 140,000 miles. here is a link http://www.lucasoil.com/products/display_products_overviews.sd?iid=2&catid=6
Danny Raddatz
