Look what I found cleaning out the barn.
GeneD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeneD14 Quote  Post ReplyReply Direct Link To This Post Topic: Look what I found cleaning out the barn.
    Posted: 31 Jan 2021 at 11:50am
My uncle gave this to me about 10 years ago. I ran across it last week cleaning thing up.
What is it???[
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 11:54am
spring hitch for wc  ,I have seen used for plowing
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 12:21pm
I've only seen them on early WD's  that wasn't equipped with the snap coupler bell
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 1:51pm
Yep, in the parts catalog it's in the section for the WD pickup plow (the mounted plow used before snap coupler came out). It's called a shock spring in there. Everything on that plow was rigidly pinned to the tractor so I presume the shock spring lessened the impact if you plowed into a rock or other object.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 3:09pm
Dad's 1950 WD had one on it. Picture taken about 1951 or 52. That's me on an uncle's lap there. Ain't I a handsome cuss. Wonder what happened through the years. The tires are the type with the continuous center rib. Still have the tractor and restored after I retired. Don't know what happened to the spring hitch thing but it disappeared from the tractor before I remember seeing it.
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 4:05pm
I still have one of those springs mounted on my 1948 WD.
When you get into a really hard pull, you can see it working.
Yes, it was for the plow grandpa had for that tractor when he first bought it. The plow is long gone, or somewhere on the property overtaken with Kudzu. But the spring is still there , hooked to the drawbar.
See no reason to remove it.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeneD14 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 6:30pm
I’m in middle TN my zip code is 37016. I can’t ship it, but it is free to a good home. Text 812-202-9928 thanks
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 7:33pm
Yep. Had one on my 51 WD that I started farming with.A $200 tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 10:14pm
Dads WD had it before putting snap coupler on.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 7:57am
I acquired one years ago at an auction that appears to never have been used.  Was informed it was a pre snap coupler item on the WD tractor.  As mentioned above, it was used with the mounted plow.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:47am
Always thought that was an "out of the box" thought on making a spring. Pretty neat.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 9:39am
I have one with the draw bar both still painted. The plow mentioned above is quite rare. Had one of those too but donated it to a neighbor.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 10:35am
I was told it was used with a pin hitch plow.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 10:39am
I've got one of those springs too. Don't remember where it came from, been to the swap meet a couple of times, no interest. I suppose it will go again the next time I go.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 1:59pm
I have one of them here in Ohio if anyone is looking for one.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 11:01pm
I have a shock spring mounted on a 1050 WD.  It's been on that tractor my entire life.
Fantrum View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fantrum Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 11:23pm
I am made of questions.
