Local Help! `47 WD |
Post Reply | Page 12> |
bhaynes
Silver Level Joined: 23 Feb 2019 Location: Chattanooga, TN Points: 105 |
Posted: 13 Jun 2019 at 7:49pm |
I am looking for anybody close to Chattanooga, TN with experience in the WD model? PLEASE message me!
I am restoring my Great Great Grandfathers WD. It has been fully restored, but I can't get it started for the life of me. It has spark. Gas. Gas too Carb.. It IS in timing. The mag spark cables are in proper order, etc... I have tried it with the kill switch on, off and the wire not even plugged up to the magneto. I am absolutely clueless at this point. It sure looks pretty but would LOVE to have it running again. Any help would be great! Obviously if somebody with knowledge living close, would be awesome to swing over one day and take a look! :)
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Haynes!
I can almost feel your pain! Good luck and I hope a fellow Allis guy can help you trouble shoot the starting issues! Family tractors are the best! If I was close I would stop in even though I am not a mag guy! Regards, Chris
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4388 |
Have you tried removing the hose to the air filter and giving it a shot of starting fluid? If the gas is old or if it's had gas with ethanol in it, your carburetor could be dirty and some of the narrow passages could be plugged.
bhaynes
The Carb. was completely redone during the restoration. I bought a complete Zenith repair kit and took the whole thing apart. Cleaned every last piece of surface on that thing and replaced most of the parts with new. It looks like a brand new carb.
HOWEVER - I do think that is the culprit maybe. I don't think gas is getting sucked into the manifold and into the block. I know for a fact gas is getting TO the carb. But when I took the spark plug out and did the `ole sniff test, I don't smell gas. Which I would think I should if gas is being sprayed in there right? I also squirted about a tablespoon of gas into the pistons to see if I could "kick start" the process, but nothing. |
Ranse
Orange Level Joined: 11 Mar 2016 Location: Tennessee Points: 773 |
Thanks(1)
I'm only 80 miles from Chattanooga and I wouldn't care to help you out, but I'm not your guy. Since all your components are new or repaired, I'd say it probably is in your timing. I've read several times on this forum how to time an engine. I have a vague understanding of it. I'd say until you actually time one and it runs you're going to remain uncertain. I know this don't help, but good luck with your WD.
bhaynes
Thanks Ranse!
I am not sure if timing or the Carb. Something tells me the Carb isn't getting gas in it, but I know gas is flowing. (if that makes sense). For the timing, I know it is 1, 2, 4, 3. I hand cranked it until I saw Piston 1 at the top notch. Then made sure from there that the Mag. is hitting position 1 on the cap. Not sure if that is correct, but that is how I tried to time it correctly.
TimCNY
Orange Level Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
Timing would not be a factor in the fuel not being sucked into (not sprayed lol) the cylinder(s).
TimCNY
Ignition timing, that is.
jiminnd
Orange Level Joined: 16 Sep 2009 Location: Rutland ND Points: 2207 |
Did you have piston on top of compression stroke, maybe you are off one turn.
nella(Pa)
Orange Level Access Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3081 |
The no. 1 piston must be on compression stroke when putting it on top dead center for timing the motor, put your thumb in the spark plug hole to feel for compression while cranking the motor.
cabinhollow
Orange Level Joined: 24 Mar 2018 Location: SEKY Points: 327 |
I'll go with ,timing is one stroke off.
Updraft carb and on the intake stroke, the intake valves are closed. |
bhaynes
Thanks everybody! I will look at the timing again.
On the Carb issue though. Shouldn't I smell gas in the Carb?
Brian G. NY
Orange Level Joined: 12 Sep 2009 Location: 12194 Points: 2198 |
From the Manual: |
WF owner
It's very easy to remove the air cleaner hose and spray some starting fluid in. If it starts and quits, you will know it's not on the ignition side.
If it doesn't start, you will know it's on the ignition side.
bhaynes
If it starts and stops - then NOT timing basically?
If it doesn't start - then timing? ?? :)
WF owner
Thanks(1)
The surfaces aren't the problem. The problem is when one of the very narrow passages is plugged up. A teaspoon of gas probably isn't enough to get it to start. I would start with a teaspoon down each spark plug, if you don't want to use starting fluid.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
Fully restored? Is the cam timed with the crankshaft properly? You can have fuel to the carb, spark at the plugs and it won't run if the valves are opening at the wrong time. You also most likely won't have any gas being sucked into the cylinders. You could also have spark on the exhaust stoke, if you didn't have it on TDC of THE COMPRESSION stroke when you "timed" it. |
WF owner
Correct. If it's 180 degrees off, it might backfire, but it won't start. If it starts and runs anywhere near normally, the timing is right (or slightly off), but it isn't getting gas. |
Orange Level Access Joined: 12 Sep 2009 Points: 19504 |
No such thing as a 1947 WD.
CTuckerNWIL
WF owner
Has it ever run since you have had it? What has changed since the last time it ran? Did you do anything that would change the timing? Are the gears in the magneto aligned correctly?
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5637 |
The very first thing I'd do... is open up the carb drain and let it run for about a minute, then close it, then close off the fuel tank petcock and dump and replace the sediment bowl, then open the petcock again, then open the carb drain for 15 seconds, then close, and tap on the carb bowl. (*flushing it clear of any water, and proving fuel flow, making sure carb float isn't stuck).
Next, pull all four spark plugs, clean each one, connect plug wire, turn the engine over by hand and observe spark at each plug... make sure that it matches with air pressure rise in cylinder (place a finger over the plug hole while turning crank). When turned slowly, the magneto impulser should emit a loud "CLACK!" when crossing TDC. The spark should be an angry, nasty white SNAP... Anything less means magneto needs a little TLC... at minimum, clean and set points... or at most, a complete rebuild with proven condenser and points, on a proper magneto test machine. You should have ample compression resistance on every cylinder when turning hand crank. If it hasn't run in a while, the valves may be lazy and not sealing well, which would inhibit proper ignition. Make certain that there's no mouse nests in the intake or exhaust... dump the oil from the oil-bath air cleaner, disconnect the air cleaner, and clean it out thoroughly. Pull off the muffler, put a vacuum cleaner on it, and the exhaust manifold, or if it's got a wasp nest in it, remove the manifold and clean all the mud out by hand. (BTDT...) |
DaveKamp
Hee hee... if it was his great-great grandfathers, it's probably a '37 unstyled... |
Brian G. NY
Yeah, I think most of us let that "slide"......WC or WD...makes little difference when diagnosing his problem. I posted the Magneto timing procedure because I don't think, from his description of how he "timed" it, he has a full comprehension of the difference between a magneto and distributor.
bhaynes
Apologies. Fat fingered it. It is 1948. :)
bhaynes
It was a rust bucket and leaking out of every nook and crack when I got it from my grandfather. It was running about 2 years ago (maybe a little less) and then turned off and hasn't been fired up since. I took it and completely redid everything. New seals everywhere. Everything back the way it was. New Manifold, newly rebuilt carburetor, new headlights, new steering wheel, sand blasted down to the cast iron, then new primer and AC orange all the way around. The Magneto wasn't generating spark and Steve in NJ (here on the Forum) rebuilt it for me and sent it back. The generator has been cleaned, repainted and tested. New battery and new wiring harness. Also new spark plugs, gas lines, oil lines, hydraulic hoses, new hoses everywhere else. New Radiator and bolts everywhere. Oh, new Oil Bath Air Cleaner (refurbished, cleaned and painted) :) The `48 WD looks like it could be show room ready! |
bhaynes
This is the tractor before the final finish. (Looks pretty with the orange UT flag!) hehe
WF owner
Thanks(1)
It would be much better if it was an orange SYRACUSE flag....
But it does look very nice!!! Edited by WF owner - 14 Jun 2019 at 2:17pm |
CTuckerNWIL
"The mag spark cables are in proper order, etc.."
Proper order is determined by where the mag was in its cycle when it was mounted on the tractor. You have to determine when it is going to spark on one wire, and put the mag on with the engine at TDC of the compression stroke to know which wire goes where. |
Sugarmaker
Hanyes,
The family WD looks real good and is just waiting for you to get it started! You have done a lot of work on it! On the carb issue you need to open the bottom drain on the carb and allow gas to flow. (try not to hurt that new paint) Another option is to use a spray bottle with gas and spray it into the carb with the air cleaner hose off. If it trys to start and guits then fuel system is the problem. I cant help you on the mag timing. Sorry I have changed all mine to distributors. They are easier for me to trouble shoot. If I were you I would try to call Don(MO) for mag timing instructions. Regards, Chris
Edited by Sugarmaker - 14 Jun 2019 at 9:12pm |
