Knock in WD45 clutch housing |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7500 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jul 2015 at 8:33pm |
Got my WD45 running today and immediately heard a random loud knock coming from the clutch housing. Seems to disappear or be not as noticeable once the tractor is warmed up. Doesn't matter if the clutch is engaged or not.
Any idea what could be the cause? Possible throwout bearing? |
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
open the square plate and see if you can see or anything abnormal
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6069 |
If it was sitting for a long time, the throwout bearing may have had some pretty dry grease in spots, and that'd make the bearing bang around a whole lot. I'll second JW's suggestion- take off that square cover, and also the cover underneath... if something falls out and it's more magnetic than a mouse, you may have a problem. If it's a mouse, he's a mess...
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Is the knock there with the lift arms up, down or both, and is there a belt pulley on the right side of the tractor?
Edited by Don(MO) - 10 Jul 2015 at 7:16am |
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2717 |
This may not be your problem, but I had broken flywheel bolts once upon a time. It started just as a "knock" down deep in the motor; thought it might be a busted crank, but it wasn't. Still requires a split and repair. HTH.
No difference with the arms up or down, tranny in gear or out, PTO on or off.
Dave's explanation seems most plausible since the tractor has been sitting inside for 2 or 3 years without use. I'll check it out first. |
Pete from IL ![]() Silver Level ![]() Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
I don't think it is a throwout bearing. It would not even be turning when your foot is off the clutch. How is the oil pressure? Rod knock from #4 cylinder?
I like dave kamps.response,if it is more magnetic than a mouse,definitely a problem.....
![]() I never found the pin, but I suspect that it was attracted by gravity through the gauntlet of gnashing gears, leaving a path of dental-destruction and dousal of debris along it's dive to the depths. |
Yknow, if there's a broken flywheel bolt...
Brian- when yours broke, did the bolt head fraggies stay inside the cavity in the center of the clutch, and just bounce around, or did they manage to drop through? If it dropped through, did it find way to safety, or become lodged between the ring gear and flywheel housing and grind a path around the inside of the casting? |
Rick ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3697 |
I would think that the common sense thing to do would be to pull off the large clutch inspection cover and see if there's small pieces of disc springs laying on the inside of that cover. That should help tell you if there's some kind of a problem with the clutch or, at least you'll be able to see what might be going on in there. There's no way that the throwout bearing would be making a noise of any kind sitting still, since the only time it's used is when the clutch is disengaged. After that, it might be that it'll need to be dug into deeper. Good luck. Rick
Dave, no ring gear damage. Unbelievable that nothing else broke. Four new bolts fixed the problem.
it isn't coming from the srarter is it?the bendix may be hanging and not returning all the way.....
Took a look in the clutch housing today. No chunks of metal laying around anywhere. Nothing looks out of place. Just had the starter rebuilt last week, so I can rule that out.
The search continues. |
Hmmm... could it be the trans drive shaft bouncing fore/aft, or worn splines under the clutch disk, or ... hydraulic pump followers... or pump unloader being indecisive?
