Is 210 and 190 hood the same?
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Topic: Is 210 and 190 hood the same?
    Posted: 12 Apr 2021 at 10:45am
Is the 210 hood the same as a 190. If not is there value in the 210 hood
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 11:37am
no, a 210 hood is unique to the 210. They are worth anywhere from $500 to 1000 depending on condition and paint. If in rough shape, would be less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 11:47am
By part numbers, all 190-190XT-200 and 210's are all different. I'm thinking you might be able to interchange a late 190-190XT and 200 onto a 210, but the muffler and air cleaner holes are probably not cut in the same spots. As a raw unfinished part, they may have been the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 2:30pm
The 210 hood is quite a bit deeper, look at the sides where the decals are, that tells the story. Would a 190 hood fit on a 210? sure, with enough cobbling. Of course the series 1 190 hood is different from the series 2/3. The biggest difference in the series 2/3 hoods from one another is the exh hole, some were smaller for a straight pipe and others had larger hole for a round muffler.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 6:07pm
Wouldn't the 210 have a larger radiator? I would just assume the grill and hood was wider.
Or did they make the rad taller not wider?
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 10:12pm
My 220 hood is made of plate steel instead of sheet metal....not really but it is one heavy SOB!!! You can walk down it with no ill effect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 6:30am
220 hoods were stout!!  210's were same gauge as the 190 hood. The grille on a 210 is actually a late 190 grille with a mesh screen on the bottom, so that gives you a feel for the hoods width.
